Saltar al contenido principal
Motorola V557 Internal Speaker Replacement
Qué necesitas
  1. Motorola V557 Internal Speaker Replacement, Battery: paso 1, imagen 1 de 3 Motorola V557 Internal Speaker Replacement, Battery: paso 1, imagen 2 de 3 Motorola V557 Internal Speaker Replacement, Battery: paso 1, imagen 3 de 3
    • First, on the back of the phone find the silver button on the top left corner of the phone.
    • Simultaneously push down the button and slide the back plate down to reveal the battery.
  2. Motorola V557 Internal Speaker Replacement: paso 2, imagen 1 de 2 Motorola V557 Internal Speaker Replacement: paso 2, imagen 2 de 2
    • Grab the lower edge of the battery at the two bottom corners.
    • Pull upward on the edges to remove the battery.
  3. Motorola V557 Internal Speaker Replacement, Faceplate: paso 3, imagen 1 de 3 Motorola V557 Internal Speaker Replacement, Faceplate: paso 3, imagen 2 de 3 Motorola V557 Internal Speaker Replacement, Faceplate: paso 3, imagen 3 de 3
    • Remove the four rubber stoppers from around the screen with a pin to reveal four screws.
  4. Motorola V557 Internal Speaker Replacement: paso 4, imagen 1 de 2 Motorola V557 Internal Speaker Replacement: paso 4, imagen 2 de 2
    • Remove the four 3.8 mm T-6 Torx screws.
  5. Motorola V557 Internal Speaker Replacement: paso 5, imagen 1 de 2 Motorola V557 Internal Speaker Replacement: paso 5, imagen 2 de 2
    • Separate the cover from the edges using a plastic opening tool.
  6. Motorola V557 Internal Speaker Replacement: paso 6, imagen 1 de 2 Motorola V557 Internal Speaker Replacement: paso 6, imagen 2 de 2
    • With the edges separated, close the phone and lift off the faceplate with your fingers.
  7. Motorola V557 Internal Speaker Replacement, Camera: paso 7, imagen 1 de 1
    • Gently peel off the plastic film from the metal plate above the camera lens as shown.
  8. Motorola V557 Internal Speaker Replacement: paso 8, imagen 1 de 2 Motorola V557 Internal Speaker Replacement: paso 8, imagen 2 de 2
    • Insert the spudger into the slots marked and gently pry upwards to remove the metal cover.
    • Repeat the previous bullet for the two corresponding tabs on the opposite side of the phone.
  9. Motorola V557 Internal Speaker Replacement: paso 9, imagen 1 de 2 Motorola V557 Internal Speaker Replacement: paso 9, imagen 2 de 2
    • Lift and peel back the tape attaching metal casing to body of the phone.
    • Gently lift the metal cover and remove to expose the circuit board.
  10. Motorola V557 Internal Speaker Replacement: paso 10, imagen 1 de 2 Motorola V557 Internal Speaker Replacement: paso 10, imagen 2 de 2
    • Using a plastic opening tool, pry or lift open the pink door shown.
    • After the door is open, gently pull on the ribbon cable's corner to separate it from the board.
    • Work out the ribbon cable's end slowly and gently to avoid damaging the pink door port.
  11. Motorola V557 Internal Speaker Replacement: paso 11, imagen 1 de 3 Motorola V557 Internal Speaker Replacement: paso 11, imagen 2 de 3 Motorola V557 Internal Speaker Replacement: paso 11, imagen 3 de 3
    • Use a plastic opening tool to dislodge and remove the rubber camera cover.
  12. Motorola V557 Internal Speaker Replacement: paso 12, imagen 1 de 2 Motorola V557 Internal Speaker Replacement: paso 12, imagen 2 de 2
    • Lift the top ribbon cable, with camera attached, up and away from the rest of the phone.
  13. Motorola V557 Internal Speaker Replacement, Screen: paso 13, imagen 1 de 3 Motorola V557 Internal Speaker Replacement, Screen: paso 13, imagen 2 de 3 Motorola V557 Internal Speaker Replacement, Screen: paso 13, imagen 3 de 3
    • Pull the ribbon cable up and out of the way to get access to the circuit board-screen unit.
    • Using a plastic opening tool, gently pry and remove the circuit board-screen unit in both screens.
  14. Motorola V557 Internal Speaker Replacement, Internal Speaker: paso 14, imagen 1 de 2 Motorola V557 Internal Speaker Replacement, Internal Speaker: paso 14, imagen 2 de 2
    • Pry the speaker out of the case by wedging a pin under the wire mesh.
    • The speaker is glued to the case. It will take some effort to remove, but don't worry, it is not fragile.
Conclusión
Equipo
Cal Poly, Team 7-50, Amido Fall 2010 Miembro de Cal Poly, Team 7-50, Amido Fall 2010
CPSU-AMIDO-F10S7G50
4 Miembros
24 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 12
Todo El Tiempo: 1,549
