Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
  1. Remove the four rubber stoppers from around the screen with a pin to reveal four screws. Remove the four rubber stoppers from around the screen with a pin to reveal four screws. Remove the four rubber stoppers from around the screen with a pin to reveal four screws.
    • Remove the four rubber stoppers from around the screen with a pin to reveal four screws.
  2. Remove the four 3.8 mm T-6 Torx screws. Remove the four 3.8 mm T-6 Torx screws.
    • Remove the four 3.8 mm T-6 Torx screws.
  3. Separate the cover from the edges using a plastic opening tool. Separate the cover from the edges using a plastic opening tool.
    • Separate the cover from the edges using a plastic opening tool.
  4. With the edges separated, close the phone and lift off the faceplate with your fingers. With the edges separated, close the phone and lift off the faceplate with your fingers.
    • With the edges separated, close the phone and lift off the faceplate with your fingers.
Conclusión
Blair Frandeen
Miembro Desde 02/10/10
19 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 7-50, Amido Fall 2010 Miembro de Cal Poly, Team 7-50, Amido Fall 2010
CPSU-AMIDO-F10S7G50
4 Miembros
24 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,886
