Saltar al contenido principal
Introducción
This section will show how to remove the external speaker from the intermediate back-casing of a Motorola V557 phone.
  1. Push down on the silver button while sliding the back plate down to reveal the battery. Push down on the silver button while sliding the back plate down to reveal the battery. Push down on the silver button while sliding the back plate down to reveal the battery.
    • Push down on the silver button while sliding the back plate down to reveal the battery.
  2. Grab the lower edge of battery at the black areas and pull upward on the edges to remove it. Grab the lower edge of battery at the black areas and pull upward on the edges to remove it.
    • Grab the lower edge of battery at the black areas and pull upward on the edges to remove it.
  3. Move the the metal slider towards the top of the phone until it clicks out of its original position. Slide out and remove the SIM card. Slide out and remove the SIM card.
    • Move the the metal slider towards the top of the phone until it clicks out of its original position.
    • Slide out and remove the SIM card.
  4. Grip the antenna and twist it counterclockwise to loosen it. When it has been loosened all the way, pull gently to remove the antenna piece.
    • Grip the antenna and twist it counterclockwise to loosen it.
    • When it has been loosened all the way, pull gently to remove the antenna piece.
  5. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  6. Remove the screw covers over the two top screws by prying gently with a pin. The large cover in the upper left of the back plate has no screw behind it, so should not be removed. The large cover in the upper left of the back plate has no screw behind it, so should not be removed.
    • Remove the screw covers over the two top screws by prying gently with a pin.
    • The large cover in the upper left of the back plate has no screw behind it, so should not be removed.
  7. Remove all four 6.0 mm Torx screws. Remove all four 6.0 mm Torx screws. Remove all four 6.0 mm Torx screws.
    • Remove all four 6.0 mm Torx screws.
  8. Insert a spudger into marked holes, one at a time, and pry away from the phone to release internal tabs. Separate and detach the rear casing. Separate and detach the rear casing.
    • Insert a spudger into marked holes, one at a time, and pry away from the phone to release internal tabs.
    • Separate and detach the rear casing.
  9. Lift out the headphone jack section from the sides using a push pin. Lift out the headphone jack section from the sides using a push pin. Lift out the headphone jack section from the sides using a push pin.
    • Lift out the headphone jack section from the sides using a push pin.
  10. Using metal tweezers, lift out the black plastic support piece from beneath the headphone jack. Using metal tweezers, lift out the black plastic support piece from beneath the headphone jack.
    • Using metal tweezers, lift out the black plastic support piece from beneath the headphone jack.
  11. Separate the speaker from the casing by pushing with a pin from the back (external) side, through the openings in the casing. Be gentle! The wire mesh is durable, but it might suffer damage if you push too hard with the pin. Be gentle! The wire mesh is durable, but it might suffer damage if you push too hard with the pin.
    • Separate the speaker from the casing by pushing with a pin from the back (external) side, through the openings in the casing.
    • Be gentle! The wire mesh is durable, but it might suffer damage if you push too hard with the pin.
Conclusión
Alex Georges
Miembro Desde 02/10/10
25 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 7-50, Amido Fall 2010 Miembro de Cal Poly, Team 7-50, Amido Fall 2010
CPSU-AMIDO-F10S7G50
4 Miembros
24 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 844
