Introducción
This guide is for replacing a key on the keypad. Super glue is required.
Qué necesitas
Press down on the chrome button on the bottom of the chassis. Simultaneously slide the back cover down, away from the phone.
Remove the rubber screw covers using a plastic spudger.
Use a T6 Torx screwdriver to remove the screws underneath the rubber screw covers.
Push both side keys in so they are not sticking out of the phone.
Remove the keypad.
Gently squeeze the bottle of super glue so that only a small amount (about 1/3 pinky width) is a applied to the back side of the key.
Una persona más ha completado esta guía.
