Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
This guide is for removing the phone's earpiece speaker.
  1. Using a spudger, remove the four rubber covers from over the screws. Using a spudger, remove the four rubber covers from over the screws. Using a spudger, remove the four rubber covers from over the screws.
    • Using a spudger, remove the four rubber covers from over the screws.
  2. Unscrew the four cover screws using the T6 bit.
    • Unscrew the four cover screws using the T6 bit.
  3. Loosen and remove the cover with a plastic opening tool. Loosen and remove the cover with a plastic opening tool.
    • Loosen and remove the cover with a plastic opening tool.
  4. Kits para Nintendo Switch
    Una solución rápida para volver al juego
    Comprar kits de Switch
  5. Gently loosen the protective cover with the plastic opening tool. Gently loosen the protective cover with the plastic opening tool.
    • Gently loosen the protective cover with the plastic opening tool.
  6. Carefully remove the protective cover from the circuitry Slowly peel the black rubber gasket up off the circuit board. Carefully move the camera out of the way using your hand.
    • Carefully remove the protective cover from the circuitry
    • Slowly peel the black rubber gasket up off the circuit board.
    • Carefully move the camera out of the way using your hand.
    • Use a flat tool to separate the connection between the upper and lower circuit boards.
  7. Gently slip the copper strip out from under the circutry by hand. Gently slip the copper strip out from under the circutry by hand. Gently slip the copper strip out from under the circutry by hand.
    • Gently slip the copper strip out from under the circutry by hand.
  8. Pry out the speaker using your fingers. Pry out the speaker using your fingers. Pry out the speaker using your fingers.
    • Pry out the speaker using your fingers.
Conclusión
gregatron
Miembro Desde 29/10/09
105 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 6-6, Maness Fall 2009 Miembro de Cal Poly, Team 6-6, Maness Fall 2009
CPSU-MANESS-F09S6G6
4 Miembros
12 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 2,598
