Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
This guide is used for taking apart and/or replacing the circuit board of the phone.
  1. Push down on the chrome button at the bottom of the back of the phone. Slide the outer casing down to reveal the battery Push down on the chrome button at the bottom of the back of the phone. Slide the outer casing down to reveal the battery
    • Push down on the chrome button at the bottom of the back of the phone. Slide the outer casing down to reveal the battery
  2. Apply pressure to the bottom corners of the battery, and then push upwards to lever the battery out.
    • Apply pressure to the bottom corners of the battery, and then push upwards to lever the battery out.
  3. Remove the rubber screw covers using a plastic spudger. Use a T-6 screw bit to remove the screws. Use a T-6 screw bit to remove the screws.
    • Remove the rubber screw covers using a plastic spudger.
    • Use a T-6 screw bit to remove the screws.
  4. Kits para Nintendo Switch
    Una solución rápida para volver al juego
    Comprar kits de Switch
  5. Unscrew the antenna.
    • Unscrew the antenna.
  6. Use a plastic opening tool to undo the latches at the indicated spots. Dental tools may be used in place of a plastic opening tool, as they are difficult to use. Warning: exercise caution as the plastic can break.
    • Use a plastic opening tool to undo the latches at the indicated spots.
    • Dental tools may be used in place of a plastic opening tool, as they are difficult to use.
    • Warning: exercise caution as the plastic can break.
  7. Remove the circuit board connection (copper flap) by first loosening it with a plastic opening tool. Lift the connection up with your finger.
    • Remove the circuit board connection (copper flap) by first loosening it with a plastic opening tool.
    • Lift the connection up with your finger.
  8. Use your finger to remove the pressure pad from the buttons on the side of the casing. Remove the plastic flap from around the buttons by lifting it up and pulling it out. Gently lift the logic board up.
    • Use your finger to remove the pressure pad from the buttons on the side of the casing.
    • Remove the plastic flap from around the buttons by lifting it up and pulling it out.
    • Gently lift the logic board up.
Conclusión
3 personas más completaron esta guía.
gregatron
Miembro Desde 29/10/09
105 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 6-6, Maness Fall 2009 Miembro de Cal Poly, Team 6-6, Maness Fall 2009
CPSU-MANESS-F09S6G6
4 Miembros
12 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 3,010
