Saltar al contenido principal
Introducción
The outer housing can be removed to be cleaned or swapped to a custom housing.
Partes
No se especificaron partes.
  1. Remove the rearmost panel by pushing down on the silver button, then simultaneously pulling downward on the panel. Lift the panel off of the phone. Lift the panel off of the phone.
    • Remove the rearmost panel by pushing down on the silver button, then simultaneously pulling downward on the panel.
    • Lift the panel off of the phone.
  2. Using your thumbnail or a thin flat head screwdriver, peel back the screen protector on the inside of the phone: It is only held on by glue but may take a good amount of force to be removed. Using your thumbnail or a thin flat head screwdriver, peel back the screen protector on the inside of the phone: It is only held on by glue but may take a good amount of force to be removed. Using your thumbnail or a thin flat head screwdriver, peel back the screen protector on the inside of the phone: It is only held on by glue but may take a good amount of force to be removed.
    • Using your thumbnail or a thin flat head screwdriver, peel back the screen protector on the inside of the phone: It is only held on by glue but may take a good amount of force to be removed.
  3. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  4. Unscrew the four screws using the T6 Torx Screwdriver. Unscrew the four screws using the T6 Torx Screwdriver.
    • Unscrew the four screws using the T6 Torx Screwdriver.
  5. Peel back the screen protector frame. Close phone at the hinge, then pull off the front outer casing. Peel back the screen protector frame. Close phone at the hinge, then pull off the front outer casing. Peel back the screen protector frame. Close phone at the hinge, then pull off the front outer casing.
    • Peel back the screen protector frame. Close phone at the hinge, then pull off the front outer casing.
Conclusión
Minh Tran
Miembro Desde 15/01/10
2 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 4-15, Forte Winter 2010 Miembro de Cal Poly, Team 4-15, Forte Winter 2010
CPSU-FORTE-W10S4G15
5 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 2,031
