Saltar al contenido principal
Motorola V276 Speaker Replacement
Qué necesitas
  1. Motorola V276 Speaker Replacement, Battery: paso 1, imagen 1 de 1
    • Locate the silver button on the back of the phone, near the bottom.
    • Depress the silver button with one hand and slide the back cover of the phone away from the antenna.
    • The back cover should slide off easily.
  2. Motorola V276 Speaker Replacement: paso 2, imagen 1 de 1
    • Insert a plastic spudger near one corner of the battery (preferably one furthest from the phone's antenna).
    • Gently pry the battery up and away from the phone. The battery should easily raise out of its place.
    • Now that the battery is exposed, use your fingers to remove the it from the phone.
  3. Motorola V276 Speaker Replacement: paso 3, imagen 1 de 2 Motorola V276 Speaker Replacement: paso 3, imagen 2 de 2
    • Note the metal connections on the phone, which are now exposed with the battery removed.
    • There are corresponding metal connectors on the replacement battery.
    • When you install the battery, be sure both connectors are matched up. Otherwise, your battery will be unable to supply power to your phone.
  4. Motorola V276 Speaker Replacement, Speaker: paso 4, imagen 1 de 1
    • Use Spudger to remove rubber plug from upper left corner of the back of the phone
  5. Motorola V276 Speaker Replacement: paso 5, imagen 1 de 1
    • Using a Hex T6 screwdriver, remove the 4 screws holding the back plate of the phone in place
  6. Motorola V276 Speaker Replacement: paso 6, imagen 1 de 3 Motorola V276 Speaker Replacement: paso 6, imagen 2 de 3 Motorola V276 Speaker Replacement: paso 6, imagen 3 de 3
    • Using your hands, pull up on the back plate while pulling on the 3 side tabs to remove the back plate.
    • Be careful when removing the back plate; don't put too much stress on the back plate or the plastic may snap
  7. Motorola V276 Speaker Replacement: paso 7, imagen 1 de 2 Motorola V276 Speaker Replacement: paso 7, imagen 2 de 2
    • On the back casing, using a spudger, push into the headphone jack at an upward angle to pop it out
  8. Motorola V276 Speaker Replacement: paso 8, imagen 1 de 2 Motorola V276 Speaker Replacement: paso 8, imagen 2 de 2
    • Using tweezers or your hands, pick out the semicircular plastic border between the speaker and headphone jack
  9. Motorola V276 Speaker Replacement: paso 9, imagen 1 de 1
    • Using a spudger, remove the speaker
Conclusión
Kyle Klitzner
Miembro Desde 04/11/10
1 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 27-96, Amido Spring 2010 Miembro de Cal Poly, Team 27-96, Amido Spring 2010
CPSU-AMIDO-S10S27G96
4 Miembros
15 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 1,005
