Saltar al contenido principal
Introducción
A guide for replacing or inspecting the Motorola V276 ear speaker
  1. Using the iPod opening tool, place the tool in the small crack that runs along the side of the front case to pry it off
    • Using the iPod opening tool, place the tool in the small crack that runs along the side of the front case to pry it off
  2. Using the T6 Torx Screwdriver remove all 4 small screws.
    • Using the T6 Torx Screwdriver remove all 4 small screws.
  3. Kits de Reparación de Batería de iPhone
    Sólo $29.99
    Buy Now
    Sólo $29.99
    Buy Now
  4. Remove silver plate from phone.
    • Remove silver plate from phone.
  5. Using the spudger, remove the plastic camera casing
    • Using the spudger, remove the plastic camera casing
  6. Pull back the logic board
    • Pull back the logic board
  7. Underneath the logic board, use your hands or a spudger to remove the ear speaker
    • Underneath the logic board, use your hands or a spudger to remove the ear speaker
Conclusión
Kyle Klitzner
Miembro Desde 11/04/10
1 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 27-96, Amido Spring 2010 Miembro de Cal Poly, Team 27-96, Amido Spring 2010
CPSU-AMIDO-S10S27G96
4 Miembros
15 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 1,542
