Saltar al contenido principal
Motorola V2397 Motherboard/Screen Replacement
Qué necesitas
  1. Motorola V2397 Motherboard/Screen Replacement, Battery: paso 1, imagen 1 de 3 Motorola V2397 Motherboard/Screen Replacement, Battery: paso 1, imagen 2 de 3 Motorola V2397 Motherboard/Screen Replacement, Battery: paso 1, imagen 3 de 3
    • Press and hold the button on the battery cover
    • Pull the battery cover down and out to remove it
  2. Motorola V2397 Motherboard/Screen Replacement: paso 2, imagen 1 de 2 Motorola V2397 Motherboard/Screen Replacement: paso 2, imagen 2 de 2
    • Remove the batteries by pulling them away from the phone
  3. Motorola V2397 Motherboard/Screen Replacement, Back Cover: paso 3, imagen 1 de 2 Motorola V2397 Motherboard/Screen Replacement, Back Cover: paso 3, imagen 2 de 2
    • Using the Torx T4 screwdriver remove the six screws highlighted in the picture to the left
  4. Motorola V2397 Motherboard/Screen Replacement: paso 4, imagen 1 de 2 Motorola V2397 Motherboard/Screen Replacement: paso 4, imagen 2 de 2
    • Use your fingers or a spudger to remove the back cover
  5. Motorola V2397 Motherboard/Screen Replacement, Phone: paso 5, imagen 1 de 2 Motorola V2397 Motherboard/Screen Replacement, Phone: paso 5, imagen 2 de 2
    • Place your plastic opening tool in between the motherboard and the front cover of the phone
    • Apply a small force to lift the motherboard away from the front cover
  6. Motorola V2397 Motherboard/Screen Replacement, Motherboard/Screen: paso 6, imagen 1 de 2 Motorola V2397 Motherboard/Screen Replacement, Motherboard/Screen: paso 6, imagen 2 de 2
    • Use your fingers to unhook the highlighted plastic frame of the screen from motherboard
    • Carefully separate the screen from the motherboard
    • Note the cable connecting the screen to the motherboard. Do not pull the screen too far from the motherboard or you may damage the cable
  7. Motorola V2397 Motherboard/Screen Replacement: paso 7, imagen 1 de 2 Motorola V2397 Motherboard/Screen Replacement: paso 7, imagen 2 de 2
    • Lift the flap of the connector on the motherboard using a spudger
    • Carefully remove the FFC cable from the connector
    • The screen should now be free from the motherboard
Conclusión
Chris
Miembro Desde 01/13/15
501 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 1-6, Sullivan Winter 2015 Miembro de USF Tampa, Team 1-6, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G6
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 145
