Saltar al contenido principal
Motorola V2397 Front Cover Replacement
Qué necesitas
  1. Motorola V2397 Front Cover Replacement, Battery: paso 1, imagen 1 de 3 Motorola V2397 Front Cover Replacement, Battery: paso 1, imagen 2 de 3 Motorola V2397 Front Cover Replacement, Battery: paso 1, imagen 3 de 3
    • Press and hold the button on the battery cover
    • Pull the battery cover down and out to remove it
  2. Motorola V2397 Front Cover Replacement: paso 2, imagen 1 de 2 Motorola V2397 Front Cover Replacement: paso 2, imagen 2 de 2
    • Remove the batteries by pulling them away from the phone
  3. Motorola V2397 Front Cover Replacement, Back Cover: paso 3, imagen 1 de 2 Motorola V2397 Front Cover Replacement, Back Cover: paso 3, imagen 2 de 2
    • Using the Torx T4 screwdriver remove the six screws highlighted in the picture to the left
  4. Motorola V2397 Front Cover Replacement: paso 4, imagen 1 de 2 Motorola V2397 Front Cover Replacement: paso 4, imagen 2 de 2
    • Use your fingers or a spudger to remove the back cover
  5. Motorola V2397 Front Cover Replacement, Side Buttons: paso 5, imagen 1 de 2 Motorola V2397 Front Cover Replacement, Side Buttons: paso 5, imagen 2 de 2
    • Lift and remove buttons by hand
  6. Motorola V2397 Front Cover Replacement, Phone: paso 6, imagen 1 de 2 Motorola V2397 Front Cover Replacement, Phone: paso 6, imagen 2 de 2
    • Place your plastic opening tool in between the motherboard and the front cover of the phone
    • Apply a small force to lift the motherboard away from the front cover
  7. Motorola V2397 Front Cover Replacement, Keypad: paso 7, imagen 1 de 3 Motorola V2397 Front Cover Replacement, Keypad: paso 7, imagen 2 de 3 Motorola V2397 Front Cover Replacement, Keypad: paso 7, imagen 3 de 3
    • Grip the top of the rubber keypad with your thumb and index finger
    • While holding the keypad start to peel it back from the front cover until the keypad is completely detached
  8. Motorola V2397 Front Cover Replacement, Speaker: paso 8, imagen 1 de 2 Motorola V2397 Front Cover Replacement, Speaker: paso 8, imagen 2 de 2
    • Use the iFixit opening tool to lift the speaker off the front cover.
  9. Motorola V2397 Front Cover Replacement, Front Cover: paso 9, imagen 1 de 2 Motorola V2397 Front Cover Replacement, Front Cover: paso 9, imagen 2 de 2
    • Once the motherboard, speaker, and keypad have been removed you should have the front cover by itself
Conclusión
Connor
Miembro Desde 01/13/15
201 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 1-6, Sullivan Winter 2015 Miembro de USF Tampa, Team 1-6, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G6
Miembros de 4
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 127
