Saltar al contenido principal
Motorola V190 Display Screen Replacement
Qué necesitas
  1. Motorola V190 Display Screen Replacement, Display Screen: paso 1, imagen 1 de 3 Motorola V190 Display Screen Replacement, Display Screen: paso 1, imagen 2 de 3 Motorola V190 Display Screen Replacement, Display Screen: paso 1, imagen 3 de 3
    • Remove the four 6.3mm TR6 Torx screws surrounding the screen.
    • Use the iFixit opening tool to separate the casing.
    • To further separate the casing, start at the top of the screen, and run the opening tool along the edges.
    • Remove the face plate by pulling it from the top hinge.
  2. Motorola V190 Display Screen Replacement: paso 2, imagen 1 de 1
    • Use the soldering iron to separate the ribbon from the phone.
  3. Motorola V190 Display Screen Replacement: paso 3, imagen 1 de 1
    • Use the iFixit opening tool to remove the screen from the plastic casing .
  4. Motorola V190 Display Screen Replacement: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Use the precision tweezers set to remove the black rectangular piece from the phone casing.
  5. Motorola V190 Display Screen Replacement: paso 5, imagen 1 de 1
    • Use the precision tweezers set to remove the rectangular ribbon from the green display board.
  6. Motorola V190 Display Screen Replacement: paso 6, imagen 1 de 2 Motorola V190 Display Screen Replacement: paso 6, imagen 2 de 2
    • Remove the display screen from the phone.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 8
Todo El Tiempo: 207
