Saltar al contenido principal
Motorola V180 Motherboard Replacement
Qué necesitas
  1. Motorola V180 Motherboard Replacement, Battery: paso 1, imagen 1 de 3 Motorola V180 Motherboard Replacement, Battery: paso 1, imagen 2 de 3 Motorola V180 Motherboard Replacement, Battery: paso 1, imagen 3 de 3
    • Completely power off the Motorola V180.
    • Flip the phone over to its back side.
    • Press down the button and slide off the back cover.
    • Remove the old battery.
  2. Motorola V180 Motherboard Replacement, Motherboard: paso 2, imagen 1 de 3 Motorola V180 Motherboard Replacement, Motherboard: paso 2, imagen 2 de 3 Motorola V180 Motherboard Replacement, Motherboard: paso 2, imagen 3 de 3
    • Use your T6 Torx Screwdriver to unscrew the four screws located on the back of the phone.
    • Remove the SIM card located on the back of the phone.
    • A ribbon near the antenna is still attached to the motherboard. Do not break this ribbon.
  3. Motorola V180 Motherboard Replacement: paso 3, imagen 1 de 2 Motorola V180 Motherboard Replacement: paso 3, imagen 2 de 2
    • Unclip the pronged rectangle connector ribbon attached to the motherboard.
    • Remove the motherboard by lifting it up out of the keypad.
Conclusión
Tyler Knisley
Miembro Desde 05/07/10
1 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 6-16, Maness Spring 2010 Miembro de Cal Poly, Team 6-16, Maness Spring 2010
CPSU-MANESS-S10S6G16
4 Miembros
13 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 1,579
