Saltar al contenido principal
Motorola Talkabout FV700R Front Faceplate Replacement
Qué necesitas
  1. Motorola Talkabout FV700R Front Faceplate Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the back battery cover by pressing the tab to the left, and lifting.
    • A small screwdriver can aid this process.
  2. Motorola Talkabout FV700R Front Faceplate Replacement: paso 2, imagen 1 de 1
    • Remove the batteries currently in the radio.
    • When you're ready to add new batteries, place Ni-MH or AAA replacement batteries in the specified slots.
    • The orientation of the batteries is specified in the battery compartment.
  3. Motorola Talkabout FV700R Front Faceplate Replacement, Volume Knob: paso 3, imagen 1 de 1
    • Turn the Volume knob to the off position.
  4. Motorola Talkabout FV700R Front Faceplate Replacement: paso 4, imagen 1 de 2 Motorola Talkabout FV700R Front Faceplate Replacement: paso 4, imagen 2 de 2
    • Firmly grasp and pull back on the volume knob. The knob should come off smoothly.
    • This may require some twisting and force.
  5. Motorola Talkabout FV700R Front Faceplate Replacement, Front Faceplate: paso 5, imagen 1 de 1
    • Remove the four 3 millimeter T6 Torx screws from the front of the radio.
  6. Motorola Talkabout FV700R Front Faceplate Replacement: paso 6, imagen 1 de 2 Motorola Talkabout FV700R Front Faceplate Replacement: paso 6, imagen 2 de 2
    • Remove the four 3 millimeter T8 Torx screws from the back of the radio.
  7. Motorola Talkabout FV700R Front Faceplate Replacement: paso 7, imagen 1 de 3 Motorola Talkabout FV700R Front Faceplate Replacement: paso 7, imagen 2 de 3 Motorola Talkabout FV700R Front Faceplate Replacement: paso 7, imagen 3 de 3
    • Gently open the backplate of the radio. Use a flathead screwdriver to slowly pry apart the two sides.
    • Be careful, as the antenna is still attached. Pulling the two sides apart too quickly could break the antenna.
  8. Motorola Talkabout FV700R Front Faceplate Replacement: paso 8, imagen 1 de 2 Motorola Talkabout FV700R Front Faceplate Replacement: paso 8, imagen 2 de 2
    • Gently pull the circuit board away from the front faceplate.
    • Be careful not to tug the wire connecting the circuit board to the speaker, as it is still attached to the faceplate.
    • Do not touch the the button contacts on the circuit board (the button contacts are shown in the red box of the second picture). This can cause long-term damage to the radio unless you properly clean them (see Repairing Motorola TALKABOUT FV700 Two Way Radio Button Contacts Guide).
Conclusión
Jack Harrison
Miembro Desde 03/26/14
188 Reputación
1 Guía escrita
Equipo
Clemson, Team 6-4, Benson Spring 2014 Miembro de Clemson, Team 6-4, Benson Spring 2014
CLEM-BENSON-S14S6G4
Miembros de 3
7 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 7
Todo El Tiempo: 759
