Saltar al contenido principal
Motorola T720c Battery Replacement
  1. Motorola T720c Battery Replacement, Battery: paso 1, imagen 1 de 1
    • On the back of the phone, locate the tab with the down arrow.
    • Using your finger, press the tab and slide the back cover down to release it from the phone.
  2. Motorola T720c Battery Replacement: paso 2, imagen 1 de 1
    • Inserting your finger in the recess at the top edge of the battery, pull the battery away from the housing to remove it.
  3. Motorola T720c Battery Replacement, Battery: paso 3, imagen 1 de 2 Motorola T720c Battery Replacement, Battery: paso 3, imagen 2 de 2
    • Locate the stepped indentations on the front of the battery.
    • With the front of the battery facing outward, insert the bottom edge into the battery housing and press battery into the phone .
    • Replace the back cover (not shown).
Conclusión
Kristina King
Miembro Desde 10/15/12
1 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 12
Todo El Tiempo: 278
