Saltar al contenido principal
Introducción
Use this guide to replace the keypad.
  1. Push down on the black tab located at the top center of the Motorola phone
    • Push down on the black tab located at the top center of the Motorola phone
  2. Remove the battery by pulling the battery from the top center
    • Remove the battery by pulling the battery from the top center
  3. Remove the four (4) T6 Torx screws from the rear metal plate.
    • Remove the four (4) T6 Torx screws from the rear metal plate.
  4. Insert the flat end of a spudger and pry the metal cover up off the phone Insert the flat end of a spudger and pry the metal cover up off the phone
    • Insert the flat end of a spudger and pry the metal cover up off the phone
  5. Carefully, disconnect the two connectors from their sockets on the motherboard using the flat end of a spudger. Carefully, disconnect the two connectors from their sockets on the motherboard using the flat end of a spudger.
    • Carefully, disconnect the two connectors from their sockets on the motherboard using the flat end of a spudger.
  6. Use a spudger to pry the antenna cable connectors from its respective socket on the motherboard.
    • Use a spudger to pry the antenna cable connectors from its respective socket on the motherboard.
    • De-route the antenna cable by pulling it out.
  7. Starting at one side, use a spudger to lift and remove the black plastic screw cover at the bottom of the phone near the speaker
    • Starting at one side, use a spudger to lift and remove the black plastic screw cover at the bottom of the phone near the speaker
    • The cover is attached by several clips, so some force may be required, especially to unclip the first clip.
    • Be careful not to loose the round plastic piece that covers the microphone.
  8. Remove the two newly exposed T6 screws. Remove the two newly exposed T6 screws.
    • Remove the two newly exposed T6 screws.
  9. Starting at the top, insert the flat end of a spudger and pry the frame of the phone. The frame is attached by several clips, so some force may be required to dislodge the first clip.
    • Starting at the top, insert the flat end of a spudger and pry the frame of the phone.
    • The frame is attached by several clips, so some force may be required to dislodge the first clip.
    • Work your tool around the entire edge of the phone, moving as soon as you hear a clip come undone, to avoid breaking the frame.
  10. Carefully, Insert the flat end of a spudger and pry the keyboard up off the phone. Carefully, Insert the flat end of a spudger and pry the keyboard up off the phone.
    • Carefully, Insert the flat end of a spudger and pry the keyboard up off the phone.
Conclusión
2 personas más completaron esta guía.
Jorge Trujillo
Miembro Desde 19/05/11
520 Reputación
4 Guías creadas
Equipo
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 5,462
