Introducción
The silver face plate is attached to the back side of the motherboard and gives stability to the port connections on the back of the device. It may need to be removed to access the port connections, or to replace the face plate itself if it has become damaged.
Qué necesitas
Locate the single 1 cm screw on the back of the device (enclosed by a red circle in the image).
Using a screwdriver with a Torx 10 hex screw, begin removing the 1cm screw by turning the screwdriver counterclockwise.
Remove the screw and set aside.
Locate the two horizontal slots on the bottom of the device.
Insert the back end of the forceps into one of these slots. You may also use any other flat, narrow tool that fits into the slots.
Gently push the forceps into device. You should feel movement or hear a click, signifying this side of the device is unlocked.
Repeat with the other slot to completely unlock the device.
Grab the top and the bottom of the device and gently pull the device open.
Continue pulling until you have completely removed the top cover of the device.
After opening the router, grab the upper left corner of the sliver face plate and gently pull the motherboard out of the slot from within the case.
Begin by grabbing the washer on the silver antennae jack screw.
Start unscrewing the washer by turning it counterclockwise.
Continue to unscrew the washer until it comes off the screw.
Set the washer aside.
Grab both corner ends of the silver face plate.
Gently pull the face plate away from the router, gently wiggling it off the screw.
Follow these directions in reverse order to replace a new face plate, or put the same faceplate back in place after you have finished working on the electrical components underneath.
2 personas más completaron esta guía.
