Introducción
The Keypad Replacement Guide provides a list of the tools and parts that you need to replace the keypad on the Motorola SLVR L9. As you begin the replacement process, look for the pictures provided with each step to better guide you.
Qué necesitas
Turn the phone over so that the back of the phone is facing towards you.
Use the plastic opening tool to loosen the cover latch.
Once the cover latch has been loosened, gently pull the cover latch off of the device.
Use a screwdriver with a T6 Torx screwdriver head to remove both screws (1/8") from the speaker housing. Turn the screw counter-clockwise (left).
