Saltar al contenido principal
Motorola SLVR L9 Camera Lens Cover Replacement
Qué necesitas
  1. Motorola SLVR L9 Camera Lens Cover Replacement, Camera Lens Cover: paso 1, imagen 1 de 2 Motorola SLVR L9 Camera Lens Cover Replacement, Camera Lens Cover: paso 1, imagen 2 de 2
    • Turn the phone over so that the back of the phone is facing towards you.
  2. Motorola SLVR L9 Camera Lens Cover Replacement: paso 2, imagen 1 de 3 Motorola SLVR L9 Camera Lens Cover Replacement: paso 2, imagen 2 de 3 Motorola SLVR L9 Camera Lens Cover Replacement: paso 2, imagen 3 de 3
    • Press down on the battery cover latch located at the top of the phone.
    • Pull the battery cover down and away from the latch; then lift it up to remove the battery cover.
  3. Motorola SLVR L9 Camera Lens Cover Replacement: paso 3, imagen 1 de 1
    • Remove the four housing screws (1/8") from each corner of the transceiver PC board shield. Use a screwdriver with a T6 Torx screwdriver head to turn the screws counter-clockwise (left).
  4. Motorola SLVR L9 Camera Lens Cover Replacement: paso 4, imagen 1 de 2 Motorola SLVR L9 Camera Lens Cover Replacement: paso 4, imagen 2 de 2
    • Once you have removed all of the screws, lift the transceiver PC board shield up to remove it.
Conclusión
Una persona más ha completado esta guía.
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 5
Ultimos 30 días: 13
Todo El Tiempo: 193
