Saltar al contenido principal
Motorola SLVR L9 Antenna Cover Replacement
Qué necesitas
  1. Motorola SLVR L9 Antenna Cover Replacement, Battery: paso 1, imagen 1 de 2 Motorola SLVR L9 Antenna Cover Replacement, Battery: paso 1, imagen 2 de 2
    • Turn the phone over so that the back of the phone is facing up.
  2. Motorola SLVR L9 Antenna Cover Replacement: paso 2, imagen 1 de 3 Motorola SLVR L9 Antenna Cover Replacement: paso 2, imagen 2 de 3 Motorola SLVR L9 Antenna Cover Replacement: paso 2, imagen 3 de 3
    • Press down on the silver battery cover latch located at the top of the phone.
    • Pull the battery cover down and away from the latch; then lift it up to remove the battery cover.
  3. Motorola SLVR L9 Antenna Cover Replacement: paso 3, imagen 1 de 3 Motorola SLVR L9 Antenna Cover Replacement: paso 3, imagen 2 de 3 Motorola SLVR L9 Antenna Cover Replacement: paso 3, imagen 3 de 3
    • To remove the battery, pull the battery up from the bottom center.
  4. Motorola SLVR L9 Antenna Cover Replacement, Antenna Cover: paso 4, imagen 1 de 3 Motorola SLVR L9 Antenna Cover Replacement, Antenna Cover: paso 4, imagen 2 de 3 Motorola SLVR L9 Antenna Cover Replacement, Antenna Cover: paso 4, imagen 3 de 3
    • Use the plastic opening tool to loosen the cover latch.
    • Once the cover latch has been loosened, gently pull the cover latch off of the device.
Conclusión
Eric Lopez
Miembro Desde 10/13/15
201 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 8
Ultimos 30 días: 13
Todo El Tiempo: 143
