Saltar al contenido principal
Motorola Razr V3m Screen/Camera Replacement
Qué necesitas
  1. Motorola Razr V3m Screen/Camera Replacement, Battery: paso 1, imagen 1 de 2 Motorola Razr V3m Screen/Camera Replacement, Battery: paso 1, imagen 2 de 2
    • Press the release button located on the upper edge of the battery cover. At the same time, lift the battery cover away from the phone.
  2. Motorola Razr V3m Screen/Camera Replacement: paso 2, imagen 1 de 2 Motorola Razr V3m Screen/Camera Replacement: paso 2, imagen 2 de 2
    • Push the top edge of the battery and lift away from the phone.
  3. Motorola Razr V3m Screen/Camera Replacement, Screen/Camera: paso 3, imagen 1 de 2 Motorola Razr V3m Screen/Camera Replacement, Screen/Camera: paso 3, imagen 2 de 2
    • Remove the 4 screws on the corners of the inside screen with the T4 screwdriver
    • The phone may have rubber plugs covering the screws of the inside screen. If so, remove the rubber plugs with a thin metal needle.
  4. Motorola Razr V3m Screen/Camera Replacement: paso 4, imagen 1 de 1
    • Use a plastic opening tool to pry the external shell off of the phone.
    • Use care when doing this step because you don’t want the external shell or the pieces inside the phone to break.
  5. Motorola Razr V3m Screen/Camera Replacement: paso 5, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Remove the two side buttons with tweezers.
  6. Motorola Razr V3m Screen/Camera Replacement: paso 6, imagen 1 de 1
    • Use tweezers to remove the circular magnetic ring covering the camera.
  7. Motorola Razr V3m Screen/Camera Replacement: paso 7, imagen 1 de 2 Motorola Razr V3m Screen/Camera Replacement: paso 7, imagen 2 de 2
    • Use a spudger to pry the screen from the inside front part of the phone.
    • You may choose to use tweezers to remove the screen instead.
Conclusión
Una persona más ha completado esta guía.
Daniel Simcock
Miembro Desde 10/24/15
731 Reputación
6 Guías creadas
Equipo
UMass Dartmouth, Team 3-2, Shastany Fall 2015 Miembro de UMass Dartmouth, Team 3-2, Shastany Fall 2015
UMASSD-SHASTANY-F15S3G2
4 Miembros
7 Guías creadas
Un comentario
where can this part be purchased?
Alex Alexander - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 418
