Introducción
This guide will show you how to remove and replace the screen for a Motorola V3c.
Partes
No se requieren partes.
Remove the four rubber pieces from all corners of the area that borders the screen.
  • Remove the four rubber pieces from all corners of the area that borders the screen.
Agregar Comentario
Use a T4 screwdriver to carefully unscrew all four screws on the outer screen.
  • Use a T4 screwdriver to carefully unscrew all four screws on the outer screen.
  • Be sure that you do not strip or damage the screws.
Agregar Comentario
  • Carefully pry the screen away from the phone using a plastic spudger.
  • Pry slowly, as too much bending will crack the screen. There are also two fragile ribbon cables that connect the screen and camera to the phone.
Agregar Comentario
  • Take the screen housing off of the casing.
  • Watch for small pieces falling out of the screen during this step. Keep track of these pieces.
Agregar Comentario
  • Pry screen cover off with plastic spudger.
  • The screen cover has some adhesive holding it to the screen
Agregar Comentario
  • Remove small black sticker covering the camera ribbon connector.
Agregar Comentario
  • Flip over small hinge that covers the camera ribbon connection.
Agregar Comentario
  • Pull off the rubber camera cover and camera.
  • The camera and camera cover may come off either separately or together.
Agregar Comentario
  • Disconnect the metallic ribbon cover.
Agregar Comentario
  • Remove and replace the screen.
Agregar Comentario
Linea de Meta
Una persona más ha completado esta guía.
Joshua Ruehlig
Miembro Desde 14/01/10
503 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 11-4, Forte Winter 2010 Miembro de Cal Poly, Team 11-4, Forte Winter 2010
CPSU-FORTE-W10S11G4
3 Miembros
8 Guías creadas
Is it a T5 or a T4 for removing the screws?
Francis Reyes - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 9
Todo El Tiempo: 8,945
