Introducción
This guide will show you how to remove the motherboard on a Motorola V3c.
Partes
No se requieren partes.
  1. Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c.
    • Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c.
    • Lift and remove the rear panel away from the V3c.
    With the phone closed, press the silver button shown with a fingernail or such. Tilt and lift the battery cover and put aside.
    walltoall - Contestar
  2. Remove the battery by pushing in the top of the battery and lifting it away from the phone.
    • Remove the battery by pushing in the top of the battery and lifting it away from the phone.
    The Motorola V3 battery has a notch in one corner to ensure it can only go in one way. Fit the replacement battery by offering its bottom edge to the device, then tilt and click using thumb pressure.
    • Unscrew the two screws in the back using the T6.
    Agregar Comentario
  3. Reparte el espíritu de reparación esta Navidad
    Obtén $12 de descuento en tu compra de $50 o más con el código FIXMAS12
    • Use the spudger to pop the bottom and the sides of the back casing
    • Be careful not to pull the back lower cover off too far as it is connected to the phone body by a ribbon
    Agregar Comentario
    • Peel off the connector between the motherboard and the body of the phone
    Agregar Comentario
    • Pull out the two black rubber covers using tweezers
    • The second rubber cover is much harder to get out
    Agregar Comentario
    • Pull out the white plastic cover by unclipping the two plastic pieces shown
    Agregar Comentario
    • Pull out the speaker
    Agregar Comentario
    • Pull out the motherboard.
    • You may also now replace the bottom lower casing
    Agregar Comentario
Conclusión
6 personas más completaron esta guía.
Joshua Ruehlig
Miembro Desde 14/01/10
503 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 11-4, Forte Winter 2010 Miembro de Cal Poly, Team 11-4, Forte Winter 2010
CPSU-FORTE-W10S11G4
3 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 11
Todo El Tiempo: 6,391
