Saltar al contenido principal
Motorola Razr V3c Lower Casing (CDMA) Replacement
Qué necesitas
  1. Motorola Razr V3c Lower Casing (CDMA) Replacement, Battery (CDMA): paso 1, imagen 1 de 3 Motorola Razr V3c Lower Casing (CDMA) Replacement, Battery (CDMA): paso 1, imagen 2 de 3 Motorola Razr V3c Lower Casing (CDMA) Replacement, Battery (CDMA): paso 1, imagen 3 de 3
    • Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c.
    • Lift and remove the rear panel away from the V3c.
  2. Motorola Razr V3c Lower Casing (CDMA) Replacement: paso 2, imagen 1 de 2 Motorola Razr V3c Lower Casing (CDMA) Replacement: paso 2, imagen 2 de 2
    • Remove the battery by pushing in the top of the battery and lifting it away from the phone.
  3. Motorola Razr V3c Lower Casing (CDMA) Replacement, Speaker (CDMA): paso 3, imagen 1 de 1
    • Unscrew the two screws in the back using the T6.
  4. Motorola Razr V3c Lower Casing (CDMA) Replacement: paso 4, imagen 1 de 1
    • Use the plastic opening tool to pop the bottom and the sides off the back casing.
    • Be careful not to pull the back lower cover off too far as it is connected to the phone body by a ribbon.
  5. Motorola Razr V3c Lower Casing (CDMA) Replacement: paso 5, imagen 1 de 1
    • Peel off the connector between the motherboard and the body of the phone.
  6. Motorola Razr V3c Lower Casing (CDMA) Replacement: paso 6, imagen 1 de 2 Motorola Razr V3c Lower Casing (CDMA) Replacement: paso 6, imagen 2 de 2
    • Pull out the two black rubber covers using tweezers.
    • The second rubber cover is much harder to get out.
  7. Motorola Razr V3c Lower Casing (CDMA) Replacement: paso 7, imagen 1 de 2 Motorola Razr V3c Lower Casing (CDMA) Replacement: paso 7, imagen 2 de 2
    • Pull out the white plastic cover by unclipping the two plastic pieces shown.
  8. Motorola Razr V3c Lower Casing (CDMA) Replacement: paso 8, imagen 1 de 1
    • Pull out the speaker.
  9. Motorola Razr V3c Lower Casing (CDMA) Replacement, Motherboard (CDMA): paso 9, imagen 1 de 2 Motorola Razr V3c Lower Casing (CDMA) Replacement, Motherboard (CDMA): paso 9, imagen 2 de 2
    • Pull out the motherboard.
    • You may also now replace the bottom lower casing
  10. Motorola Razr V3c Lower Casing (CDMA) Replacement, Lower Casing (CDMA): paso 10, imagen 1 de 1
    • Unscrew the two screws holding the plastic speaker cover to the phone with a T5 screwdriver
  11. Motorola Razr V3c Lower Casing (CDMA) Replacement: paso 11, imagen 1 de 1
    • Pull off and replace the lower front casing
    • The metallic grounding grid will come off when the lower front casing is removed
    • Make sure to reinsert the metallic grounding unit when re-screwing the new lower bottom casing
Conclusión
Una persona más ha completado esta guía.
krisko
Miembro Desde 01/14/10
104 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 11-4, Forte Winter 2010 Miembro de Cal Poly, Team 11-4, Forte Winter 2010
CPSU-FORTE-W10S11G4
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 6,240
