Introducción
The purpose of this repair guide is to show how to replace the lower outer casing.
Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c. Lift and remove the rear panel away from the V3c. Lift and remove the rear panel away from the V3c.
  • Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c.
  • Lift and remove the rear panel away from the V3c.
With the phone closed, press the silver button shown with a fingernail or such. Tilt and lift the battery cover and put aside.
walltoall - Contestar
Remove the battery by pushing in the top of the battery and lifting it away from the phone. Remove the battery by pushing in the top of the battery and lifting it away from the phone.
  • Remove the battery by pushing in the top of the battery and lifting it away from the phone.
The Motorola V3 battery has a notch in one corner to ensure it can only go in one way. Fit the replacement battery by offering its bottom edge to the device, then tilt and click using thumb pressure.
Unscrew the two screws in the back using the T6.
  • Unscrew the two screws in the back using the T6.
Agregar Comentario
Use the spudger to pop the bottom  and the sides of the back casing
  • Use the spudger to pop the bottom and the sides of the back casing
  • Be careful not to pull the back lower cover off too far as it is connected to the phone body by a ribbon
Agregar Comentario
Peel off the connector between the motherboard and the body of the phone
  • Peel off the connector between the motherboard and the body of the phone
Agregar Comentario
Pull out the two black rubber covers using tweezers The second rubber cover is much harder to get out
  • Pull out the two black rubber covers using tweezers
  • The second rubber cover is much harder to get out
Agregar Comentario
Pull out the white plastic cover by unclipping the two plastic pieces shown Pull out the white plastic cover by unclipping the two plastic pieces shown
  • Pull out the white plastic cover by unclipping the two plastic pieces shown
Agregar Comentario
Pull out the speaker
  • Pull out the speaker
Agregar Comentario
Pull out the motherboard. You may also now replace the bottom lower casing
  • Pull out the motherboard.
  • You may also now replace the bottom lower casing
Agregar Comentario
Unscrew the two screws holding the plastic speaker cover to the phone with a T5 screwdriver
  • Unscrew the two screws holding the plastic speaker cover to the phone with a T5 screwdriver
Agregar Comentario
Pull off and replace the lower front casing
  • Pull off and replace the lower front casing
  • The metallic grounding grid will come off when the lower front casing is removed
  • Make sure to reinsert the metallic grounding unit when re-screwing the new lower bottom casing
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
krisko
Miembro Desde 14/01/10
95 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 11-4, Forte Winter 2010 Miembro de Cal Poly, Team 11-4, Forte Winter 2010
CPSU-FORTE-W10S11G4
3 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 5
Todo El Tiempo: 6,019
