Saltar al contenido principal
Motorola Razr V3c Face-Screen Replacement
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
Qué necesitas
  1. Motorola Razr V3c Face-Screen Replacement, Face-Screen: paso 1, imagen 1 de 1
    • Clear a table or desk to use as a workspace. You will need a container to place small screws as they will be used in reassembly.
  2. Motorola Razr V3c Face-Screen Replacement: paso 2, imagen 1 de 1
    • Open the phone's face.
  3. Motorola Razr V3c Face-Screen Replacement: paso 3, imagen 1 de 1
    • Unscrew the four screws located around the face plate using a 1.5mm Hex tool.
  4. Motorola Razr V3c Face-Screen Replacement: paso 4, imagen 1 de 1
    • After removing the screws, use a flat surfaced tool to take the face-screen off.
  5. Motorola Razr V3c Face-Screen Replacement: paso 5, imagen 1 de 1
    • Use this step as a checkpoint. Once the face-screen cover is off, the workspace should resemble this step’s picture.
  6. Motorola Razr V3c Face-Screen Replacement: paso 6, imagen 1 de 1
    • Carefully remove the face-screen using your fingers.
  7. Motorola Razr V3c Face-Screen Replacement: paso 7, imagen 1 de 1
    • You may now carefully install a functioning face-screen.
  8. Motorola Razr V3c Face-Screen Replacement: paso 8, imagen 1 de 1
    • After securing the face-screen into the casing, place the face screen cover back on.
  9. Motorola Razr V3c Face-Screen Replacement: paso 9, imagen 1 de 1
    • Screw in the four corner screws. After completion of this step, your phone should function properly. Enjoy!
Conclusión
Enjoy your newly inserted face-screen.
Nigel
Miembro Desde 09/06/11
133 Reputación
2 Guías creadas
Equipo
Cuesta, Team 1-5, Zipperian Fall 2011 Miembro de Cuesta, Team 1-5, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G5
1 Miembro
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 4
Todo El Tiempo: 2,822
