Saltar al contenido principal
Motorola RIZR Z3 Slider Replacement
Qué necesitas
  1. Motorola RIZR Z3 Slider Replacement, Battery: paso 1, imagen 1 de 2 Motorola RIZR Z3 Slider Replacement, Battery: paso 1, imagen 2 de 2
    • Press the panel release button on the top of the phone and simultaneously pull the rear panel away from the phone.
  2. Motorola RIZR Z3 Slider Replacement: paso 2, imagen 1 de 2 Motorola RIZR Z3 Slider Replacement: paso 2, imagen 2 de 2
    • Tilt the battery by lifting at the exposed notch.
    • Slide the battery out of its casing.
  3. Motorola RIZR Z3 Slider Replacement, Motherboard: paso 3, imagen 1 de 1
    • Use a T4 screwdriver to unscrew all six of the .216 inch screws that attach the housing to the case.
  4. Motorola RIZR Z3 Slider Replacement: paso 4, imagen 1 de 2 Motorola RIZR Z3 Slider Replacement: paso 4, imagen 2 de 2
    • Use a plastic opening tool to lift the plastic casing.
    • Pull the plastic casing directly away from the phone.
  5. Motorola RIZR Z3 Slider Replacement: paso 5, imagen 1 de 1
    • Lift the black rubber loudspeaker housing up and out of the plastic casing.
  6. Motorola RIZR Z3 Slider Replacement: paso 6, imagen 1 de 2 Motorola RIZR Z3 Slider Replacement: paso 6, imagen 2 de 2
    • Use a plastic opening tool to gently lift up the SIM card reader, located above the rubber antenna casing. You should hear a click as it releases.
    • Caution: Remove carefully, if broken, the phone will not be able to make calls.
  7. Motorola RIZR Z3 Slider Replacement: paso 7, imagen 1 de 2 Motorola RIZR Z3 Slider Replacement: paso 7, imagen 2 de 2
    • Use a plastic opening tool to pry the two ribbon cable connectors, unclipping them from their sockets on the motherboard.
    • Caution: Remove carefully, if broken, the phone will not function properly.
  8. Motorola RIZR Z3 Slider Replacement: paso 8, imagen 1 de 2 Motorola RIZR Z3 Slider Replacement: paso 8, imagen 2 de 2
    • Use a plastic opening tool to gently pry the motherboard up until you can tilt it with your fingers. Unhook it from the casing and slowly pull it out.
    • Caution: Do this gently Unclipping too fast may cause damage to your phone.
  9. Motorola RIZR Z3 Slider Replacement, LCD: paso 9, imagen 1 de 1
    • Turn the phone to the front.
    • Push the keypad out through the plastic casing.
  10. Motorola RIZR Z3 Slider Replacement: paso 10, imagen 1 de 1
    • Turn the phone to the side.
    • Thread the hinges of the slider through their holes in the casing and pull the slider down and away from the casing.
  11. Motorola RIZR Z3 Slider Replacement: paso 11, imagen 1 de 1
    • Use a T4 screwdriver to unscrew the two .15 inch screws holding the LCD to the faceplate.
  12. Motorola RIZR Z3 Slider Replacement: paso 12, imagen 1 de 3 Motorola RIZR Z3 Slider Replacement: paso 12, imagen 2 de 3 Motorola RIZR Z3 Slider Replacement: paso 12, imagen 3 de 3
    • Use a spudger to pry the plastic screen casing partially up from the LCD unit.
    • Use the spudger to pry the ribbon cable away from its clip on the LCD unit.
    • Caution: Do this carefully, damage to this ribbon cable will cause a blank screen.
    • Pull the plastic screen casing directly away from the LCD unit.
  13. Motorola RIZR Z3 Slider Replacement: paso 13, imagen 1 de 2 Motorola RIZR Z3 Slider Replacement: paso 13, imagen 2 de 2
    • Use a spudger to lift the LCD partially away from the metal casing.
    • Use the spudger to pry the ribbon cable directly up from its clip on the metal casing.
    • Caution: Damage to the ribbon cable here will cause screen damage.
    • Pull the LCD completely away from the metal casing.
  14. Motorola RIZR Z3 Slider Replacement, Slider: paso 14, imagen 1 de 2 Motorola RIZR Z3 Slider Replacement, Slider: paso 14, imagen 2 de 2
    • Use the pointed end of a spudger to push the black peg into the larger side of the slot.
    • Push the peg through so that it is completely clear of the slot.
  15. Motorola RIZR Z3 Slider Replacement: paso 15, imagen 1 de 1
    • Turn the phone around and slide the slider down its track until it is free of the casing.
    • The ribbon that fits into the rectangular slot on the slider will slip through this slot as you detach the slider.
Conclusión
Una persona más ha completado esta guía.
Andrew Vu
Miembro Desde 10/07/11
35 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 5-34, Amido Fall 2011 Miembro de Cal Poly, Team 5-34, Amido Fall 2011
CPSU-AMIDO-F11S5G34
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 1,282
