Saltar al contenido principal
Motorola RIZR Z3 LCD Replacement
Qué necesitas
  1. Motorola RIZR Z3 LCD Replacement, Battery: paso 1, imagen 1 de 2 Motorola RIZR Z3 LCD Replacement, Battery: paso 1, imagen 2 de 2
    • Press the panel release button on the top of the phone and simultaneously pull the rear panel away from the phone.
  2. Motorola RIZR Z3 LCD Replacement: paso 2, imagen 1 de 2 Motorola RIZR Z3 LCD Replacement: paso 2, imagen 2 de 2
    • Tilt the battery by lifting at the exposed notch.
    • Slide the battery out of its casing.
  3. Motorola RIZR Z3 LCD Replacement, Motherboard: paso 3, imagen 1 de 1
    • Use a T4 screwdriver to unscrew all six of the .216 inch screws that attach the housing to the case.
  4. Motorola RIZR Z3 LCD Replacement: paso 4, imagen 1 de 2 Motorola RIZR Z3 LCD Replacement: paso 4, imagen 2 de 2
    • Use a plastic opening tool to lift the plastic casing.
    • Pull the plastic casing directly away from the phone.
  5. Motorola RIZR Z3 LCD Replacement: paso 5, imagen 1 de 1
    • Lift the black rubber loudspeaker housing up and out of the plastic casing.
  6. Motorola RIZR Z3 LCD Replacement: paso 6, imagen 1 de 2 Motorola RIZR Z3 LCD Replacement: paso 6, imagen 2 de 2
    • Use a plastic opening tool to gently lift up the SIM card reader, located above the rubber antenna casing. You should hear a click as it releases.
    • Caution: Remove carefully, if broken, the phone will not be able to make calls.
  7. Motorola RIZR Z3 LCD Replacement: paso 7, imagen 1 de 2 Motorola RIZR Z3 LCD Replacement: paso 7, imagen 2 de 2
    • Use a plastic opening tool to pry the two ribbon cable connectors, unclipping them from their sockets on the motherboard.
    • Caution: Remove carefully, if broken, the phone will not function properly.
  8. Motorola RIZR Z3 LCD Replacement: paso 8, imagen 1 de 2 Motorola RIZR Z3 LCD Replacement: paso 8, imagen 2 de 2
    • Use a plastic opening tool to gently pry the motherboard up until you can tilt it with your fingers. Unhook it from the casing and slowly pull it out.
    • Caution: Do this gently Unclipping too fast may cause damage to your phone.
  9. Motorola RIZR Z3 LCD Replacement, LCD: paso 9, imagen 1 de 1
    • Turn the phone to the front.
    • Push the keypad out through the plastic casing.
  10. Motorola RIZR Z3 LCD Replacement: paso 10, imagen 1 de 1
    • Turn the phone to the side.
    • Thread the hinges of the slider through their holes in the casing and pull the slider down and away from the casing.
  11. Motorola RIZR Z3 LCD Replacement: paso 11, imagen 1 de 1
    • Use a T4 screwdriver to unscrew the two .15 inch screws holding the LCD to the faceplate.
  12. Motorola RIZR Z3 LCD Replacement: paso 12, imagen 1 de 3 Motorola RIZR Z3 LCD Replacement: paso 12, imagen 2 de 3 Motorola RIZR Z3 LCD Replacement: paso 12, imagen 3 de 3
    • Use a spudger to pry the plastic screen casing partially up from the LCD unit.
    • Use the spudger to pry the ribbon cable away from its clip on the LCD unit.
    • Caution: Do this carefully, damage to this ribbon cable will cause a blank screen.
    • Pull the plastic screen casing directly away from the LCD unit.
  13. Motorola RIZR Z3 LCD Replacement: paso 13, imagen 1 de 2 Motorola RIZR Z3 LCD Replacement: paso 13, imagen 2 de 2
    • Use a spudger to lift the LCD partially away from the metal casing.
    • Use the spudger to pry the ribbon cable directly up from its clip on the metal casing.
    • Caution: Damage to the ribbon cable here will cause screen damage.
    • Pull the LCD completely away from the metal casing.
Conclusión
Brooke Shuford
Miembro Desde 10/10/11
65 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 5-34, Amido Fall 2011 Miembro de Cal Poly, Team 5-34, Amido Fall 2011
CPSU-AMIDO-F11S5G34
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 953
