Introducción
This guide involves the removal of various small screws and parts so make sure you are in a clean and organized environment to avoid the loss of any components.
Qué necesitas
Use the Torx T5 Screwdriver to remove two 5.0 mm screws at the bottom of the phone.
On the back of the LCD display, release the yellow front-facing camera ribbon cable by gently lifting upward on the black retaining clip with the spudger.
Insert the spudger between the speaker and retaining clip and gently pry upward to release the earpiece speaker.
8 personas más completaron esta guía.
