Saltar al contenido principal
Motorola RAZR Maxx HD Screen Replacement
Qué necesitas
  1. Motorola RAZR Maxx HD Screen Replacement, Screen Removal: paso 1, imagen 1 de 2 Motorola RAZR Maxx HD Screen Replacement, Screen Removal: paso 1, imagen 2 de 2
    • Use the Torx T5 Screwdriver to remove two 5.0 mm screws at the bottom of the phone.
  2. Motorola RAZR Maxx HD Screen Replacement: paso 2, imagen 1 de 2 Motorola RAZR Maxx HD Screen Replacement: paso 2, imagen 2 de 2
    • To remove the SIM card, use an unfolded paperclip to press down on the metal plate on the left side of the phone until it pops up.
  3. Motorola RAZR Maxx HD Screen Replacement: paso 3, imagen 1 de 2 Motorola RAZR Maxx HD Screen Replacement: paso 3, imagen 2 de 2
    • Gently push the screen toward the top edge of the phone and tilt the screen to reveal the black flex cables.
    • Do NOT remove the screen all the way or the flex cables will be damaged.
  4. Motorola RAZR Maxx HD Screen Replacement: paso 4, imagen 1 de 2 Motorola RAZR Maxx HD Screen Replacement: paso 4, imagen 2 de 2
    • Release the two black ribbon flex cables by gently pulling up on the connection using the spudger. Then lift the screen to remove.
    • Make sure to remove the flex cables before completely removing the screen.
    • When reassembling, align the white bands on the edge of the screen so that a connection is made.
  5. Motorola RAZR Maxx HD Screen Replacement, Front-Facing Camera: paso 5, imagen 1 de 1
    • On the back of the LCD display, release the yellow front-facing camera ribbon cable by gently lifting upward on the black retaining clip with the spudger.
  6. Motorola RAZR Maxx HD Screen Replacement: paso 6, imagen 1 de 3 Motorola RAZR Maxx HD Screen Replacement: paso 6, imagen 2 de 3 Motorola RAZR Maxx HD Screen Replacement: paso 6, imagen 3 de 3
    • With a Torx T3 screwdriver, unscrew the two 2.0 mm screws on front-facing camera mounting bracket. Then lift to remove it.
  7. Motorola RAZR Maxx HD Screen Replacement: paso 7, imagen 1 de 2 Motorola RAZR Maxx HD Screen Replacement: paso 7, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers to remove the front-facing camera by lifting it from the LCD display frame.
  8. Motorola RAZR Maxx HD Screen Replacement, Earpiece Speaker: paso 8, imagen 1 de 1
    • Insert the spudger between the speaker and retaining clip and gently pry upward to release the earpiece speaker.
  9. Motorola RAZR Maxx HD Screen Replacement: paso 9, imagen 1 de 2 Motorola RAZR Maxx HD Screen Replacement: paso 9, imagen 2 de 2
    • Using a spudger, gently pry up on the lower right edge of the black earpiece speaker ribbon cable, attached to the screen, to release it from the LCD display.
Conclusión
8 personas más completaron esta guía.
Enrique
Miembro Desde 02/01/15
371 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 8-40, Amido Winter 2015 Miembro de Cal Poly, Team 8-40, Amido Winter 2015
CPSU-AMIDO-W15S8G40
5 Miembros
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 23
Todo El Tiempo: 2,808
