Saltar al contenido principal
Motorola Q700 Sidekick Motherboard Replacement
Qué necesitas
  1. Motorola Q700 Sidekick Motherboard Replacement, Phone: paso 1, imagen 1 de 1
    • When looking at the front of the phone, use the Plastic Opening Tool to pry off the four buttons located in each of the corners on the front.
  2. Motorola Q700 Sidekick Motherboard Replacement: paso 2, imagen 1 de 1
    • Turn the phone face-down. Remove the back cover, exposing the battery.
    • Use the Plastic Opening Tool to pry the battery out of the phone.
  3. Motorola Q700 Sidekick Motherboard Replacement: paso 3, imagen 1 de 1
    • Using the appropriate size Phillips screwdriver, unscrew the four screws located in each of the corners on the back of the device.
    • Although the battery is shown in this picture, please remember to make sure that it is removed in order to proceed with disassembly.
  4. Motorola Q700 Sidekick Motherboard Replacement: paso 4, imagen 1 de 1
    • After removal of the back screws, use the Plastic Opening Tool to carefully separate the top and bottom halves of the device.
  5. Motorola Q700 Sidekick Motherboard Replacement: paso 5, imagen 1 de 1
    • Using the appropriate size Phillips screwdriver, remove any screws that are attached or associated with the keypad and carefully remove keypad from the device.
  6. Motorola Q700 Sidekick Motherboard Replacement: paso 6, imagen 1 de 1
    • On the back of the device, you will see individual green and yellow technical pieces. Remove those two pieces from the phone with your fingers and set aside.
  7. Motorola Q700 Sidekick Motherboard Replacement: paso 7, imagen 1 de 1
    • You should now have all of the pieces separated and disassembled for your device.
  8. Motorola Q700 Sidekick Motherboard Replacement, Motherboard: paso 8, imagen 1 de 1
    • Complete steps for removing battery and front cover in order before continuing on to motherboard
  9. Motorola Q700 Sidekick Motherboard Replacement: paso 9, imagen 1 de 1
    • Remove all technical componets
Conclusión
Rich
Miembro Desde 04/08/13
125 Reputación
6 Guías creadas
Equipo
SUNY Cortland, Team 1-4, Getto Spring 2013 Miembro de SUNY Cortland, Team 1-4, Getto Spring 2013
SUNYCORT-GETTO-S13S1G4
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 259
