Introducción
This guide outlines the steps to disassemble the Q Global to access the internal speakers. It can be used to replace or repair a damaged speaker.
Partes
No se requieren partes.
  1. Turn the phone face down.
    • Turn the phone face down.
    • Press and hold the release button in the middle of the back panel.
    • Slide the bottom panel down to remove.
  2. Remove the battery pack by prying it out with a fingernail, screw driver or other opening tool at the tab shown. When reinserting the battery, make sure the contacts in the battery are lined up with the contacts in the phone.
    • Remove the battery pack by prying it out with a fingernail, screw driver or other opening tool at the tab shown.
    • When reinserting the battery, make sure the contacts in the battery are lined up with the contacts in the phone.
  3. Press inwardly on the upper casing until it pops out of the phone.
    • Press inwardly on the upper casing until it pops out of the phone.
  4. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  5. Slide the upper case rightward and lift up.
    • Slide the upper case rightward and lift up.
    • Lift the camera sticker so that it does not get damaged.
  6. Remove the six labeled screws with a T5 torx screw driver. Remove the six labeled screws with a T5 torx screw driver.
    • Remove the six labeled screws with a T5 torx screw driver.
  7. Once the screws are removed, use the plastic opening tool to remove the black casing.
    • Once the screws are removed, use the plastic opening tool to remove the black casing.
  8. Remove the speakers by using the plastic remover tool.
    • Remove the speakers by using the plastic remover tool.
  9. Insert the new speakers by gently pressing them down into place.
    • Insert the new speakers by gently pressing them down into place.
Conclusión
Equipo
Cal Poly, Team 6-31, Regan Fall 2012 Miembro de Cal Poly, Team 6-31, Regan Fall 2012
CPSU-REGAN-F12S6G31
5 Miembros
5 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 540
