Introducción
Being able to access the LCD display of your Motorola Q Global is important if you wish to do self-maintenance. Here, we show you how to do so.
Partes
No se requieren partes.
  1. Turn the phone face down.
    • Turn the phone face down.
    • Press and hold the release button in the middle of the back panel.
    • Slide the bottom panel down to remove.
  2. Remove the battery pack by prying it out with a fingernail, screw driver or other opening tool at the tab shown.
    • Remove the battery pack by prying it out with a fingernail, screw driver or other opening tool at the tab shown.
    • When reinserting the battery, make sure the contacts in the battery are lined up with the contacts in the phone.
    • Press inwardly on the upper casing to release.
    • Slide the upper case rightward and lift up.
    • Lift the camera sticker so that it does not get damaged.
    • Remove the 6 screws using the T5 torx screwdriver.
    • Once the screws are removed, use the plastic opening tool to remove the black casing.
    • Remove both screws on the mounted surface with a T5 screwdriver.
    • Remove the glued, mounted surface by lifting it from underneath the SIM card slot by using the plastic opening tool.
    • Lift the motherboard about 90 degrees and remove the circuit with the orange ribbon (from the keyboard) by gently lifting the circuit.
    • Separate the front plate from the circuit board.
    • The LCD screen is attached to the circuit board by a thin ribbon.
    • Switch the lock on top of the circuit entry from horizontal to vertical.
    • Insert the new LCD screen into the circuit.
Conclusión
Will Dickman
Miembro Desde 27/09/12
28 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 6-31, Regan Fall 2012 Miembro de Cal Poly, Team 6-31, Regan Fall 2012
CPSU-REGAN-F12S6G31
5 Miembros
5 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 723
