Saltar al contenido principal
Motorola Photon 4G MB855 Speaker Replacement
Qué necesitas
  1. Motorola Photon 4G MB855 Speaker Replacement, Removing the Back Cover: paso 1, imagen 1 de 2 Motorola Photon 4G MB855 Speaker Replacement, Removing the Back Cover: paso 1, imagen 2 de 2
    • Insert a plastic opening tool into the indentation at the bottom of the phone between the front and rear covers.
    • Lift the back cover from the bottom and remove it from the phone.
  2. Motorola Photon 4G MB855 Speaker Replacement, Removing the Battery: paso 2, imagen 1 de 2 Motorola Photon 4G MB855 Speaker Replacement, Removing the Battery: paso 2, imagen 2 de 2
    • Insert a plastic opening tool, or your finger, into the notch in between the sim card and the battery and lift the battery upward.
    • Remove the battery from your phone.
  3. Motorola Photon 4G MB855 Speaker Replacement, Removing Screw Covers: paso 3, imagen 1 de 3 Motorola Photon 4G MB855 Speaker Replacement, Removing Screw Covers: paso 3, imagen 2 de 3 Motorola Photon 4G MB855 Speaker Replacement, Removing Screw Covers: paso 3, imagen 3 de 3
    • Remove all five screw covers with tweezers located in the picture.
  4. Motorola Photon 4G MB855 Speaker Replacement, Removing the Midframe: paso 4, imagen 1 de 3 Motorola Photon 4G MB855 Speaker Replacement, Removing the Midframe: paso 4, imagen 2 de 3 Motorola Photon 4G MB855 Speaker Replacement, Removing the Midframe: paso 4, imagen 3 de 3
    • Remove the 10 T4 Torx screws securing the midframe to the display assembly.
    • Gently pry the midframe from the display assembly and remove it.
  5. Motorola Photon 4G MB855 Speaker Replacement, Locating the Speaker: paso 5, imagen 1 de 1
    • Locate the speaker on the back of the midframe.
  6. Motorola Photon 4G MB855 Speaker Replacement, Removing the Speaker: paso 6, imagen 1 de 2 Motorola Photon 4G MB855 Speaker Replacement, Removing the Speaker: paso 6, imagen 2 de 2
    • The speaker is attached to the midframe with adhesive. Remove carefully.
    • Use the Metal Spudger to get between the speaker and the midframe and slowly lift the speaker upwards.
    • Remove the speaker from the midframe.
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team 8-6, Leahy Fall 2014 Miembro de USF Tampa, Team 8-6, Leahy Fall 2014
USFT-LEAHY-F14S8G6
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 7
Ultimos 30 días: 8
Todo El Tiempo: 368
