Saltar al contenido principal
Motorola Photon 4G MB855 Motherboard Replacement
Qué necesitas
  1. Motorola Photon 4G MB855 Motherboard Replacement, Removing the Back Cover: paso 1, imagen 1 de 2 Motorola Photon 4G MB855 Motherboard Replacement, Removing the Back Cover: paso 1, imagen 2 de 2
    • Insert a plastic opening tool into the indentation at the bottom of the phone between the front and rear covers.
    • Lift the back cover from the bottom and remove it from the phone.
  2. Motorola Photon 4G MB855 Motherboard Replacement, Removing the Battery: paso 2, imagen 1 de 2 Motorola Photon 4G MB855 Motherboard Replacement, Removing the Battery: paso 2, imagen 2 de 2
    • Insert a plastic opening tool, or your finger, into the notch in between the sim card and the battery and lift the battery upward.
    • Remove the battery from your phone.
  3. Motorola Photon 4G MB855 Motherboard Replacement, Removing Screw Covers: paso 3, imagen 1 de 3 Motorola Photon 4G MB855 Motherboard Replacement, Removing Screw Covers: paso 3, imagen 2 de 3 Motorola Photon 4G MB855 Motherboard Replacement, Removing Screw Covers: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Remove all five screw covers with tweezers located in the picture.
  4. Motorola Photon 4G MB855 Motherboard Replacement, Removing the Midframe: paso 4, imagen 1 de 3 Motorola Photon 4G MB855 Motherboard Replacement, Removing the Midframe: paso 4, imagen 2 de 3 Motorola Photon 4G MB855 Motherboard Replacement, Removing the Midframe: paso 4, imagen 3 de 3
    • Remove the 10 T4 Torx screws securing the midframe to the display assembly.
    • Gently pry the midframe from the display assembly and remove it.
  5. Motorola Photon 4G MB855 Motherboard Replacement, Unclipping Display Data Cable: paso 5, imagen 1 de 3 Motorola Photon 4G MB855 Motherboard Replacement, Unclipping Display Data Cable: paso 5, imagen 2 de 3 Motorola Photon 4G MB855 Motherboard Replacement, Unclipping Display Data Cable: paso 5, imagen 3 de 3
    • Locate the Display Data Cables
    • Use hands or plastic opening tool to carefully pry off the connectors.
  6. Motorola Photon 4G MB855 Motherboard Replacement, Removing Motherboard: paso 6, imagen 1 de 3 Motorola Photon 4G MB855 Motherboard Replacement, Removing Motherboard: paso 6, imagen 2 de 3 Motorola Photon 4G MB855 Motherboard Replacement, Removing Motherboard: paso 6, imagen 3 de 3
    • Be careful when removing the motherboard. The earpiece is connected with small wires and adhesive. Use a thin tool to pry it off before removing the motherboard.
    • Use a plastic opening tool to gently pry off each section of the Motherboard.
    • Slowly and carefully remove the motherboard from the front panel assembly.
Conclusión
4 personas más completaron esta guía.
Eddie Krause
Miembro Desde 10/07/14
260 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 8-6, Leahy Fall 2014 Miembro de USF Tampa, Team 8-6, Leahy Fall 2014
USFT-LEAHY-F14S8G6
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 1,392
