Saltar al contenido principal
Motorola Photon 4G MB855 Headphone Jack Replacement
Qué necesitas
  1. Motorola Photon 4G MB855 Headphone Jack Replacement, Removing the Back Cover: paso 1, imagen 1 de 2 Motorola Photon 4G MB855 Headphone Jack Replacement, Removing the Back Cover: paso 1, imagen 2 de 2
    • Insert a plastic opening tool into the indentation at the bottom of the phone between the front and rear covers.
    • Lift the back cover from the bottom and remove it from the phone.
  2. Motorola Photon 4G MB855 Headphone Jack Replacement, Removing the Battery: paso 2, imagen 1 de 2 Motorola Photon 4G MB855 Headphone Jack Replacement, Removing the Battery: paso 2, imagen 2 de 2
    • Insert a plastic opening tool, or your finger, into the notch in between the sim card and the battery and lift the battery upward.
    • Remove the battery from your phone.
  3. Motorola Photon 4G MB855 Headphone Jack Replacement, Removing Screw Covers: paso 3, imagen 1 de 3 Motorola Photon 4G MB855 Headphone Jack Replacement, Removing Screw Covers: paso 3, imagen 2 de 3 Motorola Photon 4G MB855 Headphone Jack Replacement, Removing Screw Covers: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Remove all five screw covers with tweezers located in the picture.
  4. Motorola Photon 4G MB855 Headphone Jack Replacement, Removing the Midframe: paso 4, imagen 1 de 3 Motorola Photon 4G MB855 Headphone Jack Replacement, Removing the Midframe: paso 4, imagen 2 de 3 Motorola Photon 4G MB855 Headphone Jack Replacement, Removing the Midframe: paso 4, imagen 3 de 3
    • Remove the 10 T4 Torx screws securing the midframe to the display assembly.
    • Gently pry the midframe from the display assembly and remove it.
  5. Motorola Photon 4G MB855 Headphone Jack Replacement, Locating Headphone Jack: paso 5, imagen 1 de 1
    • Locate Headphone Jack attached to Midframe.
  6. Motorola Photon 4G MB855 Headphone Jack Replacement, Removing Headphone Jack: paso 6, imagen 1 de 3 Motorola Photon 4G MB855 Headphone Jack Replacement, Removing Headphone Jack: paso 6, imagen 2 de 3 Motorola Photon 4G MB855 Headphone Jack Replacement, Removing Headphone Jack: paso 6, imagen 3 de 3
    Comprar
    • Use Tweezers to gently remove Headphone Jack from the Midframe.
    • The Headphone Jack is attached with adhesive, remove carefully.
Conclusión
Una persona más ha completado esta guía.
Eddie Krause
Miembro Desde 10/07/14
260 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 8-6, Leahy Fall 2014 Miembro de USF Tampa, Team 8-6, Leahy Fall 2014
USFT-LEAHY-F14S8G6
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 333
