Saltar al contenido principal
Motorola Photon 4G MB855 Battery Replacement
Qué necesitas
  1. Motorola Photon 4G MB855 Battery Replacement, Removing the Back Cover: paso 1, imagen 1 de 2 Motorola Photon 4G MB855 Battery Replacement, Removing the Back Cover: paso 1, imagen 2 de 2
    • Insert a plastic opening tool into the indentation at the bottom of the phone between the front and rear covers.
    • Lift the back cover from the bottom and remove it from the phone.
  2. Motorola Photon 4G MB855 Battery Replacement, Removing the Battery: paso 2, imagen 1 de 2 Motorola Photon 4G MB855 Battery Replacement, Removing the Battery: paso 2, imagen 2 de 2
    • Insert a plastic opening tool, or your finger, into the notch in between the sim card and the battery and lift the battery upward.
    • Remove the battery from your phone.
Conclusión
4 personas más completaron esta guía.
Equipo
USF Tampa, Team 8-6, Leahy Fall 2014 Miembro de USF Tampa, Team 8-6, Leahy Fall 2014
USFT-LEAHY-F14S8G6
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 1,361
