Saltar al contenido principal
Motorola Nextel i880 Antenna Replacement
Qué necesitas
  1. Motorola Nextel i880 Antenna Replacement, Antenna: paso 1, imagen 1 de 1
    • Remove back cover of the phone by disengaging the clip and lifting up on the cover.
  2. Motorola Nextel i880 Antenna Replacement: paso 2, imagen 1 de 1
    • Locate the screw on the top left portion of the phone; just below the antenna. Using a T4 Torx screwdriver remove the screw.
  3. Motorola Nextel i880 Antenna Replacement: paso 3, imagen 1 de 1
    • Slide antenna out of the phone. Ensure that the protective plastic sleeve is not lost in removal.
  4. Motorola Nextel i880 Antenna Replacement: paso 4, imagen 1 de 1
    • Slide and secure new antenna into position. Make sure metal receiver is facing forward.
  5. Motorola Nextel i880 Antenna Replacement: paso 5, imagen 1 de 1
    • Reattach back cover and secure all components in place.
Conclusión
Ryan
Miembro Desde 10/19/14
9 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 209
