Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
This is a prerequisite only guide.
Suffering from a rapidly waning, or non-existent, battery life? Use this guide to replace the battery in your Motorola Moto X.
  1. Insert the tip of a spudger under the battery cable near the connector to lift it straight up from its socket. Use the flat end of a spudger to disconnect the NFC antenna cable connector. Use the flat end of a spudger to disconnect the NFC antenna cable connector.
    • Insert the tip of a spudger under the battery cable near the connector to lift it straight up from its socket.
    • Use the flat end of a spudger to disconnect the NFC antenna cable connector.
  2. Use the tip of a spudger to flip up the ZIF retaining flap from the button assembly cable connector. Slide the tip of the spudger under the button assembly cable near the connector to pull the cable straight out of its socket. Slide the tip of the spudger under the button assembly cable near the connector to pull the cable straight out of its socket.
    • Use the tip of a spudger to flip up the ZIF retaining flap from the button assembly cable connector.
    • Slide the tip of the spudger under the button assembly cable near the connector to pull the cable straight out of its socket.
  3. Kits de Reparación de Pantalla LCD de iPhone
    La opción de presupuesto, cubierta por nuestra garantía de por vida.
    Compra kits
    Reduce los costos de reparación, no la calidad.
    Compra kits
  4. Insert the flat end of a spudger under the interconnect cable to free it from the adhesive holding it to the battery. Insert the flat end of a spudger under the interconnect cable to free it from the adhesive holding it to the battery.
    • Insert the flat end of a spudger under the interconnect cable to free it from the adhesive holding it to the battery.
  5. Use the flat end of a spudger to peel the adhesive pull-tab off the top of battery. Use the flat end of a spudger to peel the adhesive pull-tab off the top of battery.
    • Use the flat end of a spudger to peel the adhesive pull-tab off the top of battery.
    • Use the adhesive pull-tab to lift the battery from its recess.
    • The battery is secured to the motherboard with mild adhesive. Peel slowly, and be careful not to bend or puncture the battery.
    • Remove the battery from the phone.
    • When reassembling your phone secure the battery with double-sided tape or pre-cut adhesive strips.
Conclusión
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
Repair didn’t go as planned? Check out our Motorola Moto X Answers community for troubleshooting help.
Sam Goldheart
Miembro Desde 18/10/12
400,663 Reputación
547 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
110 Miembros
10,618 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 11
