Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Partes
No se especificaron partes.
  1. In the following steps you will be releasing the clips holding the phone's cases together. However, the back case is also secured with an adhesive pad. After separating the clips you will use an iOpener to allow the case to fully open. Do not attempt to fully open the phone before loosening the adhesive. Insert a plastic opening tool into the seam between the front and rear covers near the SIM card slot. Slide the plastic opening tool along the seam toward the upper corner.
    • In the following steps you will be releasing the clips holding the phone's cases together. However, the back case is also secured with an adhesive pad. After separating the clips you will use an iOpener to allow the case to fully open. Do not attempt to fully open the phone before loosening the adhesive.
    • Insert a plastic opening tool into the seam between the front and rear covers near the SIM card slot.
    • Slide the plastic opening tool along the seam toward the upper corner.
  2. Carefully slide the plastic opening tool around the corner, freeing it from clips. Carefully slide the plastic opening tool around the corner, freeing it from clips.
    • Carefully slide the plastic opening tool around the corner, freeing it from clips.
  3. Pry around the top right corner of the phone between the two covers. Pry around the top right corner of the phone between the two covers.
    • Pry around the top right corner of the phone between the two covers.
  4. Run the opening tool along the seam around all four sides, separating the remaining clips holding the cover on. The plastic on the front cover is thinner near the buttons, and the buttons may move around. Go slowly to avoid damaging the buttons or the front cover. Do not push the opening tool deep into phone, or you may damage internal components.
    • Run the opening tool along the seam around all four sides, separating the remaining clips holding the cover on.
    • The plastic on the front cover is thinner near the buttons, and the buttons may move around. Go slowly to avoid damaging the buttons or the front cover.
    • Do not push the opening tool deep into phone, or you may damage internal components.
  5. Heat an iOpener and lay it over the phone for approximately 90 seconds to loosen the adhesive securing the back cover.
    • Heat an iOpener and lay it over the phone for approximately 90 seconds to loosen the adhesive securing the back cover.
  6. Starting from the SIM slot side, carefully peel the back cover off of the phone. The back cover is very flexible, but you don't want to damage any internal components by being too hasty. There is a chance that the NFC coil may remain stubbornly adhered to the back cover. If that's the case, stop peeling the cover and reapply a heated iOpener to the back cover.
    • Starting from the SIM slot side, carefully peel the back cover off of the phone.
    • The back cover is very flexible, but you don't want to damage any internal components by being too hasty.
    • There is a chance that the NFC coil may remain stubbornly adhered to the back cover. If that's the case, stop peeling the cover and reapply a heated iOpener to the back cover.
    • Do not separate the back cover entirely; it is still connected to the phone by the camera flash cable.
    • The flash cable is attached on the power/volume button side of the phone.
  7. Gently set the back cover down in a way that exposes the camera flash cable connector, but does not put strain on it.
    • Gently set the back cover down in a way that exposes the camera flash cable connector, but does not put strain on it.
  8. Use the tip of a spudger to flip up the retaining flap on the flash cable ZIF connector. Be sure to pry only on the flap itself, not on the connector. Pull the flash cable straight out of its socket.
    • Use the tip of a spudger to flip up the retaining flap on the flash cable ZIF connector.
    • Be sure to pry only on the flap itself, not on the connector.
    • Pull the flash cable straight out of its socket.
  9. Separate the back cover from the phone.
    • Separate the back cover from the phone.
Conclusión
Sam Goldheart
Miembro Desde 18/10/12
433,399 Reputación
547 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
133 Miembros
14,625 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 80
