Saltar al contenido principal
Motorola Moto X 2nd Generation Rear Camera Replacement
Qué necesitas
  1. Motorola Moto X 2nd Generation Rear Camera Replacement, Rear Camera: paso 1, imagen 1 de 3 Motorola Moto X 2nd Generation Rear Camera Replacement, Rear Camera: paso 1, imagen 2 de 3 Motorola Moto X 2nd Generation Rear Camera Replacement, Rear Camera: paso 1, imagen 3 de 3
    • Remove SIM card tray.
  2. Motorola Moto X 2nd Generation Rear Camera Replacement: paso 2, imagen 1 de 2 Motorola Moto X 2nd Generation Rear Camera Replacement: paso 2, imagen 2 de 2
    • Push the eject pin to open a gap and place a guitar pick into the gap.
  3. Motorola Moto X 2nd Generation Rear Camera Replacement: paso 3, imagen 1 de 2 Motorola Moto X 2nd Generation Rear Camera Replacement: paso 3, imagen 2 de 2
    • Slide the guitar pick to cut the adhesive sticker and peel off the back cover.
  4. Motorola Moto X 2nd Generation Rear Camera Replacement: paso 4, imagen 1 de 2 Motorola Moto X 2nd Generation Rear Camera Replacement: paso 4, imagen 2 de 2
    • Remove two pieces rubber cover which protecting the flex connectors.
  5. Motorola Moto X 2nd Generation Rear Camera Replacement: paso 5, imagen 1 de 2 Motorola Moto X 2nd Generation Rear Camera Replacement: paso 5, imagen 2 de 2
    • Release the power button connecting flex connector and battery connector carefully.
  6. Motorola Moto X 2nd Generation Rear Camera Replacement: paso 6, imagen 1 de 2 Motorola Moto X 2nd Generation Rear Camera Replacement: paso 6, imagen 2 de 2
    • Twist off all 18 black torx screws and separate the middle housing from front assembly.
  7. Motorola Moto X 2nd Generation Rear Camera Replacement: paso 7, imagen 1 de 3 Motorola Moto X 2nd Generation Rear Camera Replacement: paso 7, imagen 2 de 3 Motorola Moto X 2nd Generation Rear Camera Replacement: paso 7, imagen 3 de 3
    • Release rear camera connector and remove it easily.
Conclusión
2 personas más completaron esta guía.
Sophia
Miembro Desde 03/25/14
43,822 Reputación
62 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 987
