Introducción
This guide will show you step-by-step how to replace your worn out keyboard buttons.
Qué necesitas
Use the Push Pin to remove the rubber screw covers by pushing the needle into the rubber and pulling up.
Remove the plastic inner cover by placing the spudger under the left-most side and pry to the left and upwards.
Gently rotate/wiggle the cover until you can pull it off the phone.
Simply lift the keyboard buttons with your hands pulling from one side to the other.
