Saltar al contenido principal
Motorola Moto Q Back Casing Replacement
Qué necesitas
  1. Motorola Moto Q Back Casing Replacement, Back Casing: paso 1, imagen 1 de 1
    • Use the Push Pin to remove the rubber screw covers by pushing the needle into the rubber and pulling up.
    • Be careful not to poke yourself when handling the push pin because it is very sharp.
  2. Motorola Moto Q Back Casing Replacement: paso 2, imagen 1 de 1
    • Use the T6 screwdriver to remove the four screws holding the casing together.
    • Note: they are in the same place where you removed the four rubber coverings
  3. Motorola Moto Q Back Casing Replacement: paso 3, imagen 1 de 2 Motorola Moto Q Back Casing Replacement: paso 3, imagen 2 de 2
    • Wedge the plastic opening tool in between the top and bottom cases. This may require a little or a lot of force so be careful.
    • Note: the phone should be face up and the plastic opening tool should be face downwards
    • Once you get the plastic opening tool in, slide it across the side of the phone, making sure to keep the plastic opening tool wedged in between the two casings.
    • Repeat the 3 steps above for the top, bottom, and opposite side.
  4. Motorola Moto Q Back Casing Replacement: paso 4, imagen 1 de 2 Motorola Moto Q Back Casing Replacement: paso 4, imagen 2 de 2
    • Gently lift and remove the back casing.
Conclusión
Luis Herrera
Miembro Desde 01/21/10
52 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 16-33, Maness Winter 2010 Miembro de Cal Poly, Team 16-33, Maness Winter 2010
CPSU-MANESS-W10S16G33
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 9
Ultimos 30 días: 12
Todo El Tiempo: 5,154
