Saltar al contenido principal
Motorola Moto G7 Play Motherboard Replacement
Qué necesitas
  1. Motorola Moto G7 Play Motherboard Replacement, Back Cover: paso 1, imagen 1 de 2 Motorola Moto G7 Play Motherboard Replacement, Back Cover: paso 1, imagen 2 de 2
    • Turn off your device before you begin.
    • Use the iFixit pick to break the adhesive around the back case.
    • Use a heat gun, hairdryer, or iOpener to weaken the adhesive around the back case. If you're using the iOpener, please review the instructions for proper use.
  2. Motorola Moto G7 Play Motherboard Replacement: paso 2, imagen 1 de 1
    • Detach the back case from the phone.
    • Make sure the back is opened right to left so the cable of the fingerprint scanner does not get damaged.
  3. Motorola Moto G7 Play Motherboard Replacement: paso 3, imagen 1 de 2 Motorola Moto G7 Play Motherboard Replacement: paso 3, imagen 2 de 2
    • Use the iFixit pick and the iFixit opening tool to pull the fingerprint scanner off of the back case.
  4. Motorola Moto G7 Play Motherboard Replacement, Motherboard: paso 4, imagen 1 de 1
    • Remove the nine 3.2mm screws from the motherboard cover with a Phillips #00 screwdriver.
  5. Motorola Moto G7 Play Motherboard Replacement: paso 5, imagen 1 de 1
    • Lift motherboard cover off by the bottom.
    • Use reverse tweezers or a similar tool if needed.
  6. Motorola Moto G7 Play Motherboard Replacement: paso 6, imagen 1 de 2 Motorola Moto G7 Play Motherboard Replacement: paso 6, imagen 2 de 2
    • Once the motherboard cover is removed, disconnect the four ribbon cables and the two wires attached to the motherboard.
  7. Motorola Moto G7 Play Motherboard Replacement: paso 7, imagen 1 de 2 Motorola Moto G7 Play Motherboard Replacement: paso 7, imagen 2 de 2
    • Using the Phillips #00 screwdriver, remove the single 0.4 mm black screw in the center of the motherboard.
    • Remove the motherboard from the device.
Conclusión
2 personas más completaron esta guía.
Equipo
Cal Poly, Team S7-G4, Regan Winter 2020 Miembro de Cal Poly, Team S7-G4, Regan Winter 2020
CPSU-REGAN-W20S7G4
5 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 23
Todo El Tiempo: 2,165
