Saltar al contenido principal
Motorola Moto G7 Play Fingerprint Sensor Replacement
Qué necesitas
  1. Motorola Moto G7 Play Fingerprint Sensor Replacement, Back Cover: paso 1, imagen 1 de 2 Motorola Moto G7 Play Fingerprint Sensor Replacement, Back Cover: paso 1, imagen 2 de 2
    • Turn off your device before you begin.
    • Use the iFixit pick to break the adhesive around the back case.
    • Use a heat gun, hairdryer, or iOpener to weaken the adhesive around the back case. If you're using the iOpener, please review the instructions for proper use.
  2. Motorola Moto G7 Play Fingerprint Sensor Replacement: paso 2, imagen 1 de 1
    • Detach the back case from the phone.
    • Make sure the back is opened right to left so the cable of the fingerprint scanner does not get damaged.
  3. Motorola Moto G7 Play Fingerprint Sensor Replacement: paso 3, imagen 1 de 2 Motorola Moto G7 Play Fingerprint Sensor Replacement: paso 3, imagen 2 de 2
    • Use the iFixit pick and the iFixit opening tool to pull the fingerprint scanner off of the back case.
  4. Motorola Moto G7 Play Fingerprint Sensor Replacement, Fingerprint Sensor: paso 4, imagen 1 de 1
    • Remove the nine 3.2 mm screws from the motherboard cover with a Phillips #00 screwdriver.
  5. Motorola Moto G7 Play Fingerprint Sensor Replacement: paso 5, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Lift motherboard cover from the bottom.
    • Use reverse tweezers or a similar tool if needed
  6. Motorola Moto G7 Play Fingerprint Sensor Replacement: paso 6, imagen 1 de 2 Motorola Moto G7 Play Fingerprint Sensor Replacement: paso 6, imagen 2 de 2
    • Using the iFixit opening tool, carefully disconnect the ribbon cable connecting the fingerprint scanner to the motherboard.
    • Remove the fingerprint scanner from the device.
Conclusión
3 personas más completaron esta guía.
Equipo
Cal Poly, Team S7-G4, Regan Winter 2020 Miembro de Cal Poly, Team S7-G4, Regan Winter 2020
CPSU-REGAN-W20S7G4
5 Miembros
12 Guías creadas
Un comentario
Do you need to replace the adhesive on the rear cover? Or is it reusable?
wtwolfe - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 22
Todo El Tiempo: 1,690
