Saltar al contenido principal
Motorola Moto G7 Play Charging Port Replacement
Qué necesitas
  1. Motorola Moto G7 Play Charging Port Replacement, Back Cover: paso 1, imagen 1 de 2 Motorola Moto G7 Play Charging Port Replacement, Back Cover: paso 1, imagen 2 de 2
    • Turn off your device before you begin.
    • Use the iFixit pick to break the adhesive around the back case.
    • Use a heat gun, hairdryer, or iOpener to weaken the adhesive around the back case. If you're using the iOpener, please review the instructions for proper use.
  2. Motorola Moto G7 Play Charging Port Replacement: paso 2, imagen 1 de 1
    • Detach the back case from the phone.
    • Make sure the back is opened right to left so the cable of the fingerprint scanner does not get damaged.
  3. Motorola Moto G7 Play Charging Port Replacement: paso 3, imagen 1 de 2 Motorola Moto G7 Play Charging Port Replacement: paso 3, imagen 2 de 2
    • Use the iFixit pick and the iFixit opening tool to pull the fingerprint scanner off of the back case.
  4. Motorola Moto G7 Play Charging Port Replacement, Charging Port: paso 4, imagen 1 de 1
    • Remove the six 3.2 mm screws from the charging port assembly cover with a Phillips #00 screwdriver.
  5. Motorola Moto G7 Play Charging Port Replacement: paso 5, imagen 1 de 1
    • Using the iFixit opening tool, carefully pry up the charging port assembly cover.
  6. Motorola Moto G7 Play Charging Port Replacement: paso 6, imagen 1 de 2 Motorola Moto G7 Play Charging Port Replacement: paso 6, imagen 2 de 2
    • Using an iFixit opening tool, detach the cables from the charging port assembly.
  7. Motorola Moto G7 Play Charging Port Replacement: paso 7, imagen 1 de 1
    • Using the iFixit opening tool, carefully pry up the charging port assembly.
Conclusión
9 personas más completaron esta guía.
Equipo
Cal Poly, Team S7-G4, Regan Winter 2020 Miembro de Cal Poly, Team S7-G4, Regan Winter 2020
CPSU-REGAN-W20S7G4
5 Miembros
12 Guías creadas
Un comentario
Xt1952-4 is the same. Replaced the charge port due to microphone failing.
Travis Brubaker - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 53
Todo El Tiempo: 8,647
