Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
If you are experiencing trouble with your rear camera, chances are it has a faulty connection or it has been damaged. Follow these steps to remove your rear camera.
  1. Power off the phone before you begin. Bring the heat gun one to two inches from the edges of the display to melt the display adhesive. Spend equal amounts of time applying heat around the entire edge of the phone.
    • Power off the phone before you begin.
    • Bring the heat gun one to two inches from the edges of the display to melt the display adhesive.
    • Spend equal amounts of time applying heat around the entire edge of the phone.
  2. Attach the suction cup to the display slightly to the left of center. Exert a moderate force to pull on the suction cup. The display will come loose.
    • Attach the suction cup to the display slightly to the left of center.
    • Exert a moderate force to pull on the suction cup. The display will come loose.
  3. Insert the opening tool inside the loosened edge. Gradually work  the opening tool around the edge of the entire screen to cut through the adhesive. Do not wedge the opening tool too far beneath the screen.  Using too much force can result in torn connector cables.
    • Insert the opening tool inside the loosened edge.
    • Gradually work the opening tool around the edge of the entire screen to cut through the adhesive.
    • Do not wedge the opening tool too far beneath the screen. Using too much force can result in torn connector cables.
  4. The display should now be entirely loose,  attached only by the connectors at the top of the device and the fingerprint sensor connector at the bottom of the device. Press down on the fingerprint sensor with the display slightly raised to disconnect it from the display. If the fingerprint sensor does not come loose, use the heat gun to loosen its adhesive.
    • The display should now be entirely loose, attached only by the connectors at the top of the device and the fingerprint sensor connector at the bottom of the device.
    • Press down on the fingerprint sensor with the display slightly raised to disconnect it from the display.
    • If the fingerprint sensor does not come loose, use the heat gun to loosen its adhesive.
  5. The cables at the top of the device are fragile. If you are using this guide as a prerequisite for replacing another part, be careful not to tear the cables while lifting the screen. Remove the one 5mm Torx-5 screw located by the connector cables in the top right corner of the device.
    • The cables at the top of the device are fragile. If you are using this guide as a prerequisite for replacing another part, be careful not to tear the cables while lifting the screen.
    • Remove the one 5mm Torx-5 screw located by the connector cables in the top right corner of the device.
  6. Grab the unscrewed metal plate with your blunt tweezers. Slide the metal plate to the left and then out to remove it.
    • Grab the unscrewed metal plate with your blunt tweezers.
    • Slide the metal plate to the left and then out to remove it.
    • Removing the plate will expose the display assembly's connection to the phone's motherboard.
  7. Disengage the two cable connectors by gently prying beneath the edge of the connector with the opening tool. Disengage the two cable connectors by gently prying beneath the edge of the connector with the opening tool.
    • Disengage the two cable connectors by gently prying beneath the edge of the connector with the opening tool.
  8. Lift up the detached right connector from its housing using blunt tweezers. The housing has light adhesive underneath it. Use a small amount of force to remove the connector from the housing.
    • Lift up the detached right connector from its housing using blunt tweezers.
    • The housing has light adhesive underneath it. Use a small amount of force to remove the connector from the housing.
  9. Remove the nine black 5mm Torx-5 screws.
    • Remove the nine black 5mm Torx-5 screws.
    • Remove the seven silver 5mm Torx-5 screws.
  10. Remove the metal cover by prying underneath it with the opening tool. Remove the metal cover by prying underneath it with the opening tool.
    • Remove the metal cover by prying underneath it with the opening tool.
  11. Grab ahold of the fingerprint sensor and push it through the opening in the metal cover. Grab ahold of the fingerprint sensor and push it through the opening in the metal cover. Grab ahold of the fingerprint sensor and push it through the opening in the metal cover.
    • Grab ahold of the fingerprint sensor and push it through the opening in the metal cover.
  12. Remove the fingerprint connector by gently prying underneath the connector with the opening tool. Remove the fingerprint connector by gently prying underneath the connector with the opening tool.
    • Remove the fingerprint connector by gently prying underneath the connector with the opening tool.
  13. Disengage the two cable connectors by gently prying beneath the edge of the connector with the opening tool. The camera is now fully disconnected from the device and can be removed by hand. The camera is now fully disconnected from the device and can be removed by hand.
    • The camera is now fully disconnected from the device and can be removed by hand.
Conclusión
Kevin George
Miembro Desde 08/10/18
838 Reputación
4 Guías creadas
Equipo
Cal Poly, Team S4-G5, White Fall 2018 Miembro de Cal Poly, Team S4-G5, White Fall 2018
CPSU-WHITE-F18S4G5
4 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 222
