Saltar al contenido principal
Motorola Moto G5s Plus Battery Replacement
Qué necesitas
  1. Motorola Moto G5s Plus Battery Replacement, Display: paso 1, imagen 1 de 3 Motorola Moto G5s Plus Battery Replacement, Display: paso 1, imagen 2 de 3 Motorola Moto G5s Plus Battery Replacement, Display: paso 1, imagen 3 de 3
    • Power off the phone before you begin.
    • Bring the heat gun one to two inches from the edges of the display to melt the display adhesive.
    • Spend equal amounts of time applying heat around the entire edge of the phone.
  2. Motorola Moto G5s Plus Battery Replacement: paso 2, imagen 1 de 2 Motorola Moto G5s Plus Battery Replacement: paso 2, imagen 2 de 2
    • Attach the suction cup to the display slightly to the left of center.
    • Exert a moderate force to pull on the suction cup. The display will come loose.
  3. Motorola Moto G5s Plus Battery Replacement: paso 3, imagen 1 de 3 Motorola Moto G5s Plus Battery Replacement: paso 3, imagen 2 de 3 Motorola Moto G5s Plus Battery Replacement: paso 3, imagen 3 de 3
    • Insert the opening tool inside the loosened edge.
    • Gradually work the opening tool around the edge of the entire screen to cut through the adhesive.
    • Do not wedge the opening tool too far beneath the screen. Using too much force can result in torn connector cables.
  4. Motorola Moto G5s Plus Battery Replacement: paso 4, imagen 1 de 3 Motorola Moto G5s Plus Battery Replacement: paso 4, imagen 2 de 3 Motorola Moto G5s Plus Battery Replacement: paso 4, imagen 3 de 3
    • The display should now be entirely loose, attached only by the connectors at the top of the device and the fingerprint sensor connector at the bottom of the device.
    • Press down on the fingerprint sensor with the display slightly raised to disconnect it from the display.
    • If the fingerprint sensor does not come loose, use the heat gun to loosen its adhesive.
  5. Motorola Moto G5s Plus Battery Replacement: paso 5, imagen 1 de 2 Motorola Moto G5s Plus Battery Replacement: paso 5, imagen 2 de 2
    • The cables at the top of the device are fragile. If you are using this guide as a prerequisite for replacing another part, be careful not to tear the cables while lifting the screen.
    • Remove the one 5mm Torx-5 screw located by the connector cables in the top right corner of the device.
  6. Motorola Moto G5s Plus Battery Replacement: paso 6, imagen 1 de 2 Motorola Moto G5s Plus Battery Replacement: paso 6, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Grab the unscrewed metal plate with your blunt tweezers.
    • Slide the metal plate to the left and then out to remove it.
    • Removing the plate will expose the display assembly's connection to the phone's motherboard.
  7. Motorola Moto G5s Plus Battery Replacement: paso 7, imagen 1 de 2 Motorola Moto G5s Plus Battery Replacement: paso 7, imagen 2 de 2
    • Disengage the two cable connectors by gently prying beneath the edge of the connector with the opening tool.
  8. Motorola Moto G5s Plus Battery Replacement: paso 8, imagen 1 de 2 Motorola Moto G5s Plus Battery Replacement: paso 8, imagen 2 de 2
    • Lift up the detached right connector from its housing using blunt tweezers.
    • The housing has light adhesive underneath it. Use a small amount of force to remove the connector from the housing.
  9. Motorola Moto G5s Plus Battery Replacement, Fingerprint Sensor: paso 9, imagen 1 de 1
    • Remove the nine black 5mm Torx-5 screws.
    • Remove the seven silver 5mm Torx-5 screws.
  10. Motorola Moto G5s Plus Battery Replacement: paso 10, imagen 1 de 2 Motorola Moto G5s Plus Battery Replacement: paso 10, imagen 2 de 2
    • Remove the metal cover by prying underneath it with the opening tool.
  11. Motorola Moto G5s Plus Battery Replacement: paso 11, imagen 1 de 3 Motorola Moto G5s Plus Battery Replacement: paso 11, imagen 2 de 3 Motorola Moto G5s Plus Battery Replacement: paso 11, imagen 3 de 3
    • Grab ahold of the fingerprint sensor and push it through the opening in the metal cover.
  12. Motorola Moto G5s Plus Battery Replacement: paso 12, imagen 1 de 2 Motorola Moto G5s Plus Battery Replacement: paso 12, imagen 2 de 2
    • Remove the fingerprint connector by gently prying underneath the connector with the opening tool.
  13. Motorola Moto G5s Plus Battery Replacement, Battery: paso 13, imagen 1 de 1
    • The battery is now fully exposed and ready to be removed.
  14. Motorola Moto G5s Plus Battery Replacement: paso 14, imagen 1 de 2 Motorola Moto G5s Plus Battery Replacement: paso 14, imagen 2 de 2
    • Use the opening tool to remove the two metal connectors located above the battery.
    • Apply a gentle upward pressure to loosen the metal plates.
  15. Motorola Moto G5s Plus Battery Replacement: paso 15, imagen 1 de 3 Motorola Moto G5s Plus Battery Replacement: paso 15, imagen 2 de 3 Motorola Moto G5s Plus Battery Replacement: paso 15, imagen 3 de 3
    • Using the spudger, cut downwards along the black tape on left side of the battery.
  16. Motorola Moto G5s Plus Battery Replacement: paso 16, imagen 1 de 1
    • Use the opening tool to disengage the black connector located above the battery.
  17. Motorola Moto G5s Plus Battery Replacement: paso 17, imagen 1 de 1
    • Heating up the battery excessively could cause the battery to ignite
    • Use the heat gun along the back of the phone to loosen the adhesive that holds the battery in place.
    • Spend equal intervals of time on each area applying heat.
  18. Motorola Moto G5s Plus Battery Replacement: paso 18, imagen 1 de 3 Motorola Moto G5s Plus Battery Replacement: paso 18, imagen 2 de 3 Motorola Moto G5s Plus Battery Replacement: paso 18, imagen 3 de 3
    • Insert the spudger underneath the right side of the battery.
    • Apply a moderate upward force along the length of battery, until the battery lifts out of place.
    • Remove the battery with your hand.
Conclusión
11 personas más completaron esta guía.
Kevin George
Miembro Desde 10/08/18
1,072 Reputación
4 Guías creadas
Equipo
Cal Poly, Team S4-G5, White Fall 2018 Miembro de Cal Poly, Team S4-G5, White Fall 2018
CPSU-WHITE-F18S4G5
4 Miembros
5 Guías creadas
Un comentario
Hello,
I would like to chance the battery.
But for me it isn’t not clear how to glue the screen back again. I can not find any sealing at the market
Thanks
Jirik - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 23
Ultimos 30 días: 97
Todo El Tiempo: 12,569
