Saltar al contenido principal
Motorola Moto G5 Plus Fingerprint Sensor Replacement
Qué necesitas
  1. Motorola Moto G5 Plus Fingerprint Sensor Replacement, Display Assembly: paso 1, imagen 1 de 3 Motorola Moto G5 Plus Fingerprint Sensor Replacement, Display Assembly: paso 1, imagen 2 de 3 Motorola Moto G5 Plus Fingerprint Sensor Replacement, Display Assembly: paso 1, imagen 3 de 3
    • Be sure to power off your phone before you begin.
    • Use a SIM eject bit, SIM eject tool, or paper clip to remove the SIM card from your phone.
  2. Motorola Moto G5 Plus Fingerprint Sensor Replacement: paso 2, imagen 1 de 1
    • Prepare an iOpener and heat the front of the phone along its left edge for about two minutes, or until it's slightly too hot to touch. This will help soften the adhesive securing the display.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough to cut the adhesive. Follow the iOpener instructions to avoid overheating.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  3. Motorola Moto G5 Plus Fingerprint Sensor Replacement: paso 3, imagen 1 de 3 Motorola Moto G5 Plus Fingerprint Sensor Replacement: paso 3, imagen 2 de 3 Motorola Moto G5 Plus Fingerprint Sensor Replacement: paso 3, imagen 3 de 3
    • In the following steps you will be cutting through the adhesive around the edge of the display assembly.
    • Refer to the second and third images and familiarize yourself with the width of the adhesive around edges of the display.
    • If you plan to re-use the display assembly, be particularly careful as you cut the adhesive on the sides of the phone. Don't insert your tool more than 2 mm into the phone, and angle it down (away from the display assembly) as much as possible.
  4. Motorola Moto G5 Plus Fingerprint Sensor Replacement: paso 4, imagen 1 de 3 Motorola Moto G5 Plus Fingerprint Sensor Replacement: paso 4, imagen 2 de 3 Motorola Moto G5 Plus Fingerprint Sensor Replacement: paso 4, imagen 3 de 3
    • Apply a suction cup to the display, near the middle of the left edge.
    • Pull the suction cup with firm, constant pressure to create a slight gap between the display panel and the rear case.
    • If the screen is cracked, the suction cup may not stick. In that case, try lifting with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • If the display doesn't separate even with significant force, apply more heat to further soften the adhesive and try again. The adhesive cools quickly, so you may need to heat it repeatedly.
  5. Motorola Moto G5 Plus Fingerprint Sensor Replacement: paso 5, imagen 1 de 3 Motorola Moto G5 Plus Fingerprint Sensor Replacement: paso 5, imagen 2 de 3 Motorola Moto G5 Plus Fingerprint Sensor Replacement: paso 5, imagen 3 de 3
    • Slide the tool along the left edge of the phone, cutting through the adhesive securing the display.
    • As you move on to cutting the adhesive around the rest of the display, it may help to leave an opening pick in place here and grab another for the following steps.
  6. Motorola Moto G5 Plus Fingerprint Sensor Replacement: paso 6, imagen 1 de 2 Motorola Moto G5 Plus Fingerprint Sensor Replacement: paso 6, imagen 2 de 2
    • Slide the opening pick down and cut the adhesive around the bottom of the display.
    • If the adhesive is too tough to cut, continue to heat it until it softens enough to cut fairly easily. Excessive prying or force used here could permanently damage the display or other components.
    • Be careful as you slide your pick around the top and bottom edges of the display. The display cables, fingerprint sensor, and fingerprint sensor cable are all housed fairly close to the edge of the display and can easily be damaged. Refer to this image to see the exact location of the cables.
  7. Motorola Moto G5 Plus Fingerprint Sensor Replacement: paso 7, imagen 1 de 3 Motorola Moto G5 Plus Fingerprint Sensor Replacement: paso 7, imagen 2 de 3 Motorola Moto G5 Plus Fingerprint Sensor Replacement: paso 7, imagen 3 de 3
    • Continue cutting through the adhesive on the top and right sides of the phone.
    • The proximity sensor, earpiece speaker, and front-facing camera are all located along the top edge of the phone, but are housed beneath the display unit. You shouldn't come into contact with any of them as you insert your pick to cut the adhesive.
  8. Motorola Moto G5 Plus Fingerprint Sensor Replacement: paso 8, imagen 1 de 3 Motorola Moto G5 Plus Fingerprint Sensor Replacement: paso 8, imagen 2 de 3 Motorola Moto G5 Plus Fingerprint Sensor Replacement: paso 8, imagen 3 de 3
    • Once all the adhesive is cut, carefully lift open the display from the left edge.
    • Don't fully remove the display yet. There are still cables connecting the display assembly that can rip easily.
    • Prop the display unit at a 90 degree angle against a box to prevent the display and fingerprint cables from bending or tearing.
  9. Motorola Moto G5 Plus Fingerprint Sensor Replacement: paso 9, imagen 1 de 2 Motorola Moto G5 Plus Fingerprint Sensor Replacement: paso 9, imagen 2 de 2
    • Remove the yellow sticker covering two of the black Phillips screws below the earpiece.
  10. Motorola Moto G5 Plus Fingerprint Sensor Replacement: paso 10, imagen 1 de 1
    • Remove the following Phillips screws from the midframe:
    • Sixteen 3.8 mm black screws
    • Three 2.4 mm silver screws
  11. Motorola Moto G5 Plus Fingerprint Sensor Replacement: paso 11, imagen 1 de 2 Motorola Moto G5 Plus Fingerprint Sensor Replacement: paso 11, imagen 2 de 2
    • Insert the flat end of a spudger between the midframe and the left edge of the phone and carefully pry to release the two clips holding the midframe in place.
  12. Motorola Moto G5 Plus Fingerprint Sensor Replacement: paso 12, imagen 1 de 2 Motorola Moto G5 Plus Fingerprint Sensor Replacement: paso 12, imagen 2 de 2
    • Lift the midframe up and away from the phone.
  13. Motorola Moto G5 Plus Fingerprint Sensor Replacement: paso 13, imagen 1 de 2 Motorola Moto G5 Plus Fingerprint Sensor Replacement: paso 13, imagen 2 de 2
    • Use the point of a spudger to disconnect the larger of the two display cable connectors.
  14. Motorola Moto G5 Plus Fingerprint Sensor Replacement: paso 14, imagen 1 de 3 Motorola Moto G5 Plus Fingerprint Sensor Replacement: paso 14, imagen 2 de 3 Motorola Moto G5 Plus Fingerprint Sensor Replacement: paso 14, imagen 3 de 3
    • Disconnect the smaller display cable connector.
    • This cable houses a display controller chip encased in yellow tape. You do not need to remove the yellow tape. The chip is lightly adhered to the motherboard, but should come up with minimal effort.
    • Gently continue lifting the cable to break the adhesive seal and pull the cable away from the motherboard.
  15. Motorola Moto G5 Plus Fingerprint Sensor Replacement: paso 15, imagen 1 de 2 Motorola Moto G5 Plus Fingerprint Sensor Replacement: paso 15, imagen 2 de 2
    • At the opposite end of the phone, disconnect the fingerprint sensor cable.
    • The fingerprint sensor cable is taped to a shield above it. As you lift the cable, lift the tape up with it. You can also remove the tape before disconnecting the cable.
  16. Motorola Moto G5 Plus Fingerprint Sensor Replacement: paso 16, imagen 1 de 2 Motorola Moto G5 Plus Fingerprint Sensor Replacement: paso 16, imagen 2 de 2
    • Remove the display assembly from the phone.
    • Before you reinstall the display assembly, thoroughly remove any remaining adhesive and glass from the frame of the device with isopropyl alcohol.
    • Be sure to turn on your phone and test your repair before installing new adhesive and sealing the display assembly.
    • If your replacement display doesn't have touch functionality and you're sure that it has been installed correctly, back up your data and perform a factory reset.
  17. Motorola Moto G5 Plus Fingerprint Sensor Replacement, Fingerprint Sensor: paso 17, imagen 1 de 2 Motorola Moto G5 Plus Fingerprint Sensor Replacement, Fingerprint Sensor: paso 17, imagen 2 de 2
    • Remove the fingerprint sensor button from the screen by pushing it out with your fingers.
Conclusión
4 personas más completaron esta guía.
Nicole Klukowski
Miembro Desde 10/09/17
1,552 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S1-G6, Leahy Fall 2017 Miembro de USF Tampa, Team S1-G6, Leahy Fall 2017
USFT-LEAHY-F17S1G6
5 Miembros
21 Guías creadas
2 comentarios
Any way to just clean the edges of the sensor without taking apart the entire phone?
craptop kid - Contestar
Finger print scanner connector port get completely damaged. is this the reason my phone is not getting started
Hathi Matha - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 14
Ultimos 30 días: 27
Todo El Tiempo: 4,379
