Saltar al contenido principal
Motorola Moto G5 Plus Disassembly
Sólo Prerrequisito
Esta guía solo debería usarse como prerrequisito para otras guías. Por tanto, estará incompleta.
Qué necesitas
  1. Motorola Moto G5 Plus Disassembly, Disassembly: paso 1, imagen 1 de 1
    • Power off the phone.
  2. Motorola Moto G5 Plus Disassembly: paso 2, imagen 1 de 2 Motorola Moto G5 Plus Disassembly: paso 2, imagen 2 de 2
    • Remove the SIM card using a thin paperclip by inserting one end of the paper clip into the small hole on the top left corner. This will eject the SIM card from the phone.
    • Be sure to store the SIM card in a safe location.
  3. Motorola Moto G5 Plus Disassembly: paso 3, imagen 1 de 3 Motorola Moto G5 Plus Disassembly: paso 3, imagen 2 de 3 Motorola Moto G5 Plus Disassembly: paso 3, imagen 3 de 3
    • The screen is likely to crack as you pry it up. You should not complete this step unless you have a replacement screen available.
    • Stick the small suction cup onto the screen. Use this to remove the screen from the phone frame in later steps.
    • Using a heat gun on a low setting, slowly raise the temperature of the screen by repeatedly running the heat gun along the edges of the screen. This will soften the glue that holds the screen to the phone frame.
    • Use the suction cup to gently pull up on the screen while using the plastic opening tool to gently pry the edges of the screen up.
    • Once the screen has been completely separated from the phone frame, flip it to one side to expose the inside of the phone.
  4. Motorola Moto G5 Plus Disassembly: paso 4, imagen 1 de 1
    • Using a size 000 Philips head screwdriver, unscrew the nineteen 4 mm screws. Yellow tinted kapton tape will need to be removed to get to some of the screws.
  5. Motorola Moto G5 Plus Disassembly: paso 5, imagen 1 de 2 Motorola Moto G5 Plus Disassembly: paso 5, imagen 2 de 2
    • Remove the interior metal covering using the plastic opening tool.
  6. Motorola Moto G5 Plus Disassembly: paso 6, imagen 1 de 1
    • Pull off all of the yellow tinted kapton tape.
  7. Motorola Moto G5 Plus Disassembly: paso 7, imagen 1 de 1
    • Unplug the battery by lifting up on the black plug with the plastic opening tool. This will shut off any power to the phone and prevent further damage.
    • Be careful not to damage the motherboard underneath the plugs.
  8. Motorola Moto G5 Plus Disassembly: paso 8, imagen 1 de 3 Motorola Moto G5 Plus Disassembly: paso 8, imagen 2 de 3 Motorola Moto G5 Plus Disassembly: paso 8, imagen 3 de 3
    • Remove the 3 flat-topped connectors that connect the screen to the phone frame by prying them up with the plastic opening tool.
    • Fully detach the screen and set it to the side.
Conclusión
Nicole Klukowski
Miembro Desde 10/09/17
1,534 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S1-G6, Leahy Fall 2017 Miembro de USF Tampa, Team S1-G6, Leahy Fall 2017
USFT-LEAHY-F17S1G6
5 Miembros
21 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 133
